BeatleSmith Samba Member
Posted: Mon Oct 01, 2018 1:06 pm Post subject: Firestone f560 wear on one tire |
I hope this is in the right place. My set up is lowered in the front by drop spindles and a set of firestone f560 145r14s, that was fitted about 1 yr ago. Took it to an alignment shop and they found no issues and adjusted the alignment. My problem is that now that the passenger tire is wearing far more substantial than the drivers side. Also the one that is wearing seams to be bald on the top outside and less on the bottom outside.
I called the alignment shop and they told me with an older vehicle they try to just get it in spec, rather than making it perfect like a newer vehicle. I don't feel like it would cause too much of an issue though. I am guessing this isn't normal. Seems like a toe issue to me, but i could be wrong. Anyone ever have a similar issue with a similar set up? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Oct 01, 2018 9:28 pm Post subject: Re: Firestone f560 wear on one tire |
Sounds like the "tire shop" figured out a way to sell more tires. |
jason Samba Member
Posted: Tue Oct 09, 2018 12:00 pm Post subject: Re: Firestone f560 wear on one tire |
What kind of beam? Did they only check toe? Dont like their answer. In spec is in spec so I dont follow the perfect analogy. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Oct 11, 2018 9:39 pm Post subject: Re: Firestone f560 wear on one tire |
ps2375 wrote: |
I agree. Tire shops don't train with bugs- and none of their employees drive them (just JDM stuff). Take it to a proper VW mechanic.
I reread your post 5 times and don't understand what you mean by "top outside" and "bottom outside." Your tires roll, right? If so- each half revolution becomes the other "outside." So what do you mean? _________________
EverettB wrote: |
FU#5 |
