mbwesty Samba Member
Posted: Mon Oct 01, 2018 3:16 pm Post subject: WBX Block Corrosion and Rust, Rebuildable? |
I am wondering if it is going to be more work to try rebuilding an WBX engine that's been sitting around and had some corrosion and rust on the engine studs and water jacket and head mating surface? I know there is a seal there...but can these be cleaned out nicely and install a new head?
Thanks for your comment/help! |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Mon Oct 01, 2018 3:49 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Might clean up ok, hard to say from the photo.
At the asking price of $150 not that much risked. You will likely need new cyls and pistons, and all the missing parts to make a complete longblock. Small parts can add up. Hopefully they are still with the engine like it seems from the ad.
That yellow sticker on the top of the case usually means it has been rebuilt before.
Mark |
Posted: Mon Oct 01, 2018 4:11 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Ya, thx! The engine code has been removed, so can't say for sure it's a 2.1 block originally. |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 660 Location: Lancaster PA
Posted: Tue Oct 02, 2018 6:59 am Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Yellow sticker on top means it's a factory rebuild. All of those rebuilds were line bored and have larger bearings but (sometimes?) stock crank journals. Those bearings no longer exist so you would have to have the crank ground undersized in order to use the case.
That would be the first thing i would check. |
tencentlife Samba Member
Posted: Tue Oct 02, 2018 10:32 am Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
MayorMcCheese wrote: |
Quite a few of those Cummins of Canada rebuilds were align-bored, but having torn down at least 60 of them I would say it's not even nearly half.
Still a fair chance that that one was, though, and any oversize case bearings are very hard to get here in the states, but they are available from several European vendors, with the expected higher costs. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Fri Oct 05, 2018 10:56 am Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Thanks for all the great info!!!
It ends up I got an un-opened 2.1 block from a friend who had went to subi. So I have been looking at the costs and for sure nothing is cheap anymore, and it doesn't seem like a budget rebuilt is possible. $400 for a set of offset rods to go with the QSC and etc...or....
The options are shrinking over time and GoWesty has seems to be offering the most complete solution. $1500 for the 2.2 kit or $800 for the P/L set with the copper seals...I will hv to tear the case down and take some measurements before I can decide on what to do, and what I can afford, I guess. The engine I have is approaching 200K miles, at least that's what I am aware of...this is gonna be the replacement engine hopefully in 6 months... |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Oct 05, 2018 1:27 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
The only affordable way that I can see to refresh a WBX engine is if you can reuse the cylinders and pistons with new rings and the cylinder heads need just a simple valve job. It really adds up quick with new heads, cylinders, pistons, rods etc. If you decide for your first refresh to use original parts, the 2.1 will require replacing the connecting rod fasteners. Don't skip this step. _________________ ☮️ |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Fri Oct 05, 2018 9:41 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
i'm having a 2.1 wbx rebuilt for a customer as we speak, the guy building, has be building aircooled porsche engines for 30 years plus, i have had him do a couple of type IV aircooled engines for me, they still run like sewing machines, and i know he's done the occasional the WBX, so he's doing one for one of my customers, he's expecting the final bill to come to around $2k, i hope to get a break down of what's gone into the rebuild. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Fri Oct 05, 2018 10:26 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Yes, would luv to see the break down. He's probably a lot more resourceful that I though...
markswagen wrote: |
i'm having a 2.1 wbx rebuilt for a customer as we speak, the guy building, has be building aircooled porsche engines for 30 years plus, i have had him do a couple of type IV aircooled engines for me, they still run like sewing machines, and i know he's done the occasional the WBX, so he's doing one for one of my customers, he's expecting the final bill to come to around $2k, i hope to get a break down of what's gone into the rebuild. |
Posted: Sat Oct 06, 2018 10:42 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
that's a fairly easy one to prove, the craigslist advert, the 6th picture, on the top of the engine block, where the plenum bolts to it, the last stud, by the flywheel, on the 2.1 engines, this part of the casting is thicker than the 1.9 engines.
the next casting is the one at the front on the top, between the distributor and the breather tower, again the casting is thicker there than it is on the 1.9 engines.
also under the water pump pulleyyou will see the dynamic oil pressure sender, this one i guess is easy enough to retro fit into a 1.9, so that alone would be a true indication.
the addition material, in the thicker parts of the casting, is not something that you could modify.
so i would happily say, that this is a 2.1 engine block.
mbwesty wrote: |
619 201 0310 |
Posted: Sun Oct 07, 2018 10:54 am Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Awesome info! Thank! Tim
markswagen wrote: |
mbwesty wrote: |
Posted: Sun Oct 07, 2018 9:24 pm Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
Yes, will definitely change out and use a ARP bolt. Thx!
MarkWard wrote: |
The only affordable way that I can see to refresh a WBX engine is if you can reuse the cylinders and pistons with new rings and the cylinder heads need just a simple valve job. It really adds up quick with new heads, cylinders, pistons, rods etc. If you decide for your first refresh to use original parts, the 2.1 will require replacing the connecting rod fasteners. Don't skip this step. |
Posted: Mon Oct 22, 2018 9:55 am Post subject: Re: WBX Block Corrosion and Rust, Rebuildable? |
so i ended up with this 2.1 core for the rebuild, and i have started tearing it down already...i did not pick up the one on GL...i got some questions on the heads and will post some pics soon in a new thread...thx! |
