greek_tony Samba Member
Joined: February 12, 2013 Posts: 243 Location: Athens, Greece
Posted: Tue Oct 02, 2018 11:43 am Post subject: Help needed with my icepick door handles |
I'm totally stumped.
Fitted the driver side locking door handle and the bolt holes don't align and the pointy end of the handle touches the door. Looks like the door seal (which is a plain flat piece of rubber) is pushing the rear of the handle out.
These are proper NOS door handles I got hold of about 4 years ago.
Do these door handles have a rubber seal at the base?
Is it a flat profile?
Is it a problem with the shape of the handle?
Help!!! _________________ 1963 Karmann Ghia - Sold
May 53 Ragtop - Resto started
October 65 Fastback - Almost there. |
jason Samba Member
Posted: Tue Oct 02, 2018 12:39 pm Post subject: Re: Help needed with my icepick door handles |
Pictures? Need to be flat and thin seals. |
Posted: Tue Oct 02, 2018 1:16 pm Post subject: Re: Help needed with my icepick door handles |
I'll get some pics tomorrow _________________ 1963 Karmann Ghia - Sold
Posted: Thu Oct 04, 2018 2:11 am Post subject: Re: Help needed with my icepick door handles |
I tried the handles without the seal and they seem to fit...
I've measure the seal, the position of the holes and the curve of the handle (there's about 4mm of clearance of the tip of the handle).
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
jason Samba Member
Posted: Thu Oct 04, 2018 9:03 am Post subject: Re: Help needed with my icepick door handles |
Was the door hole messed with, any filler? |
Posted: Thu Oct 04, 2018 9:39 am Post subject: Re: Help needed with my icepick door handles |
Passenger door fits fine.
Driver side door still has about 1 mm to go for the bolts to line up. Seems like the door may have an issue. _________________ 1963 Karmann Ghia - Sold
jason Samba Member
Posted: Sat Oct 06, 2018 11:36 am Post subject: Re: Help needed with my icepick door handles |
Try the handle on passenger side. If it lines up you have your answer. |
stale air Samba Member
Joined: August 23, 2007 Posts: 5148 Location: Senoia Ga, formally NorCal
Posted: Sat Oct 06, 2018 1:28 pm Post subject: Re: Help needed with my icepick door handles |
The answer may be to just push. Meaning, push the handle inward with the palm of your hand (over the lock cyl portion of the handle) while trying to line up the screws in the jam. I had the same issue with mine, using a new seal, fresh paint etc. With a little brute force, but still being super careful, I managed to get it all to line up. _________________ WANTED: Henry Veale Santa Rosa plate frames
banana split Samba Member
Joined: January 22, 2002 Posts: 1069 Location: Beautiful British Columbia Canada
Posted: Sun Oct 07, 2018 11:46 am Post subject: Re: Help needed with my icepick door handles |
Is your car a fresh repaint? If so, you probably have a build up of primer, filler and paint on the exterior that is causing this... especially since you state the handle fits without the seal in place. The NOS handles won't be the problem. _________________ My Beetles :
1953 Zwitter
1964 Chop Top |
Posted: Mon Oct 08, 2018 12:12 am Post subject: Re: Help needed with my icepick door handles |
Thanks guys.
Looks like it's what you are saying. The doors were a bit tired so needed a bit of massaging before paint.
Gonna try the "gentle" brute force _________________ 1963 Karmann Ghia - Sold
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Sun Oct 14, 2018 7:22 am Post subject: Re: Help needed with my icepick door handles |
I had the same issue on my 57 a few days ago with new paint and new seals. Just got a large C clamp and gently squeezed the back of the door handle into place and could then start the screws.
Worked slick _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Mon Oct 15, 2018 12:07 am Post subject: Re: Help needed with my icepick door handles |
Riff Raff wrote: |
Worked slick |
Good idea! _________________ 1963 Karmann Ghia - Sold
