i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Tue Oct 02, 2018 8:03 pm Post subject: Leaky Weber |
I'm rebuilding a set of Weber IDF 44s. I noticed they leak at a port that looks to be blocked off by something that looks like JB weld...
When I cleaned them I noticed the "plug" seemed to be deteriorating
Can I apply JB weld to the plug or should I take it to a carb shop? |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3456 Location: Paradise, Ca
Posted: Tue Oct 02, 2018 10:42 pm Post subject: Re: Leaky Weber |
I would not use JB Weld around gas. I tried once and the gas ate away at the JB weld till it failed.
Pull the plugs, tap them and plug them with brass counter sunk plugs. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Oct 03, 2018 7:52 am Post subject: Re: Leaky Weber |
Yes to removing offending plugs as jpaull states, and tap threads and use good Locktite sealer and thread in brass plugs....
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Oct 03, 2018 10:57 am Post subject: Re: Leaky Weber |
Those should have had lead plugs, you might be able to get them from Pierce Manifolds. _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Wed Oct 03, 2018 4:07 pm Post subject: Re: Leaky Weber |
earthquake wrote: |
Those should have had lead plugs, you might be able to get them from Pierce Manifolds. |
Thank you...I'll look into that |
Posted: Wed Oct 03, 2018 4:08 pm Post subject: Re: Leaky Weber |
Dale M. wrote: |
Dale |
Next time I tear them down I will go this route |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3777 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Oct 03, 2018 11:59 pm Post subject: Re: Leaky Weber |
JB Weld will work. But it needs to be cleaned well first then once the JB Weld is applied it needs to cure fully before being subjected to fuel.
Best done when carb is off and no fuel present. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Thu Oct 04, 2018 5:16 am Post subject: Re: Leaky Weber |
udidwht wrote: |
Best done when carb is off and no fuel present. |
Sounds like right now is the time then...
I cleaned and rebuilt them both, haven't had time to install them. I'll try the JB weld and let cure for 3 to 4 days before I install and run fuel thru them |
jpaull Samba Member
Posted: Thu Oct 04, 2018 10:33 am Post subject: Re: Leaky Weber |
I cleaned perfectly and let it cure plenty and still watched the JB weld turn to crap. I'm only mentioning this to save you from a possible mess up later. |
Posted: Thu Oct 04, 2018 2:47 pm Post subject: Re: Leaky Weber |
jpaull wrote: |
Been fine with mine since 1998. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
jpaull Samba Member
Posted: Thu Oct 04, 2018 2:53 pm Post subject: Re: Leaky Weber |
udidwht wrote: |
jpaull wrote: |
Been fine with mine since 1998. |
Hopefully OP has your luck. |
Posted: Thu Oct 04, 2018 3:53 pm Post subject: Re: Leaky Weber |
I plan on getting some JB weld tonight or tomorrow...I'm willing to give it a try, I really dont want to tear these carbs apart, dig out the lead plug, drill then tap and try to clean out all the metal from the drill |
Paul Jr Samba Member
Posted: Thu Oct 04, 2018 3:58 pm Post subject: Re: Leaky Weber |
I think I just figured out why my uncle has a bunch of bullets without caseings in one of the drawers he uses for keeping nuts, bolts, washers and other miscilainious things in. |
