Intrinsic Samba Member
Joined: November 16, 2011 Posts: 262 Location: Clearwater, FL
Posted: Fri Oct 05, 2018 11:41 am Post subject: Battery Post Extension Bolts |
I needed a clean method to add supplementary wiring to my battery posts so that I could attach a battery tender without having to lift the rear seat. The space is limited so I found these extension bolts an my FLAPS. These clean up the installation, allow for disconnection of the extra circuit without disconnecting the battery, and manage the clutter.
Here is the installation, note the brass bolts on the battery terminals.
Here it is insulated, I did add insulation over the bolt on the positive terminal.
