Looks like I have a crack in my cyl head do I need to worry ?
62 rag cruiser
62 rag cruiser is offline
PostPosted: Mon Oct 08, 2018 9:15 am    Post subject: Re: Looks like I have a crack in my cyl head do I need to worry ? Reply with quote
Thanks no worries then.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Oct 06, 2018 2:14 pm    Post subject: Re: Looks like I have a crack in my cyl head do I need to worry ? Reply with quote
Definitely a casting mark. These heads crack between the valve seats and between the spark plug hole and valve seats.
Casey--
Seven VW vans from T1 through T4 since 1985
Volkswagens powered by Volkswagen
Respect the marque
Busstom Premium Member
Busstom is offline
PostPosted: Fri Oct 05, 2018 8:21 pm    Post subject: Re: Looks like I have a crack in my cyl head do I need to worry ? Reply with quote
That looks like the parting line from casting, not a crack. That's normal, and that would be a very unusual place for the head to crack. Clean up the gasket surface, it should be fine.
Whether or not you want to worry is up to you Wink
62 rag cruiser
PostPosted: Fri Oct 05, 2018 8:12 pm    Post subject: Looks like I have a crack in my cyl head do I need to worry ? Reply with quote
I was getting ready to install a set of Kadrons I picked up a while ago and when I removed my old DP intake ends I think I have found a crack in my head at the intake port dividing web ? I am new to VW so I am not sure if this is normal to find and I need to replace the head or it is ok to just run as is. You can see in the pic that the crack is in the port dividing web. This is the left side The right side looks ok not a defined crack but looks and feels like a casting line.
Any info would be greatly appreciated.
