pjstock Samba Member
Joined: November 07, 2017 Posts: 118 Location: toronto, Ontario
Posted: Sat Oct 06, 2018 6:17 pm Post subject: 1995 2.4L diesel T4 Transporter does not start |
well, this was a surprise.
after 8 months of faultless starting (and after having been driven just yesterday) we jumped in the camper this morning to head off 2 hours in the country and .... nothing.
it cranked and cranked and cranked.
I had the choke pulled (though it usually doesn't need that)
there is fuel (though it is low, but still, one eighth or so.)
I admit this is an utterly mundane situation - a diesel that will not start. , pretty much unrelated to VW vans or campers
but what could have happened overnight?
apparently it is either fuel related (lack thereof) and so I guess I might check the fuel pump?
or it could be due to lack of compression. (but overnight?)
any insights or tips before I have this beast towed to a mechanic?
Peter |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Sat Oct 06, 2018 6:24 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Well, it doesn’t have a choke. So do some reading before diving in.
There is a stop solenoid on the injection pump, if the wire falls off you wiil have a crank no - start as you describe
If your glow plug circuit is compromised that would do the same. _________________ .ssS! |
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Sat Oct 06, 2018 6:26 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Pump could be leaking & lost its prime. Fuel shut off solenoid could be bad or wire going to it broke/fell off/chewed off by a fucking rodent (seriously). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Zeitgeist 13 Samba Member
Posted: Sat Oct 06, 2018 7:30 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Yeah, the fuel shutoff solenoid system is probably the issue _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sat Oct 06, 2018 7:45 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Abscate wrote: |
I am not clear what you mean when you say "it doesn't have a choke".
OK maybe choke is not the correct term but mine has a Cold Start handle which I think (page 6 I am supposed to pull until it gets down to -15C.
Or did I misunderstand. |
Posted: Sat Oct 06, 2018 8:30 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Anytime the dashlights are on, the solenoid should be getting 12v. If not, then you have issues with the switch or the wiring between the switch and the solenoid. The solenoid should click firmly when the ignition switch is turned on. _________________ Casey--
y u rune klassik? |
Posted: Sat Oct 06, 2018 9:14 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Hold the Phone!
so then tonight, 12 hours after our "crank no-start" morning, on a whim I jumped into the van and tried it and....
Bingo! it started! just like old times.
but that makes me nervous.
how do I understand what happened and why it would go from no-start to start?
Peter |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Sun Oct 07, 2018 12:13 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Curiouser and curiouser.....
So to recap.
Saturday AM I had crank no-start for....30minutes ( til.i gave up and rented a car for our daybtrip.)
late last night the beast fired right up, as if nothing had ever been wrong.
Today I tried again and at first got the crank nostart, then it shifted to a putt-putt-putt...... as if it were just about to combust.
And then finally, on about the 6th try she fires up.
Ran to the hardware store fine. Restarted there fine...
Do those clues add anything?
And about that solenoid question. Does the fuel solenoid always engage when Running? Or just at startup?
Did.always, does thebfactbthat once running she runs fine mean the solenoid is not the cause? |
Posted: Wed Oct 10, 2018 11:26 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
The time to find out the problem is the 30mminutes of no start.
If the engine doesn’t start in 5 seconds, somethings wrong. Cranking it on and on is just burning out your starter and battery.
Next time it won’t start, leave the key on, go back to the engine , and look for the wire attached to the diesel injection pump, with all the spider legs coming off it heading back to the cylinders. You should have 12 Volts between this terminal and ground.
Snap,a picture of your engine and we can show you where it is.
Other possibles
Bad solenoid (yes, it needs to be on to both start and run the motor. It’s an electrically operated fuel shut off)
Worn out diesel pump allowing air into your injectors. Diesels don’t like this and won’t start if they get air in the lines.
Diesel injectors are dangerous. If you get diesel injected into your skin deep enough, the medical treatment is amputation.
On edit...sorry I forgot to add guidance. The cone amd go nature of the no start is indicative of air in the lines, either from a leak in the injector path, fuel delivery, .or worn pump. The solenoid could be sticky, too. _________________ .ssS! |
Posted: Tue Oct 16, 2018 8:51 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Thank you.
is this the diesel injection pump?
the white plastic bit with the screw off lid?
Posted: Wed Oct 17, 2018 3:29 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
It’s going to be in the front of the engine, right side of car
Find the four injectors..a row of cylindrical things about 2 cm in diameter with metal pipes coming of each one. Follow the pipes to where they all meet at a big lump of metal. That’s the injection pump. Look for an electrical connection to ampnother metal thing on the pump..that’s the solenoid.
The pipes look a bit like the ones in your picture but will run right left, one for each cylinder. The pipes in the picture are brake lines
We don’t get diesel T4s here because God only gives nice things to countries that don’t screw up the world, like Canada. _________________ .ssS! |
Posted: Wed Oct 17, 2018 6:50 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
in this shot anywhere?
or here (deeper down in the cavity)
Peter |
Posted: Wed Oct 17, 2018 8:18 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Those are the injectors - just to show how little I know about your engine, its an inline 5 cylinder diesel, so there are 5 of them
The injectors have hard metal lines to deliver fuel, and then soft rubber lines looped from injector to injector to return excess fuel to the tank - this also cools them.
Follow the hard lines on each down to the injector pump - it looks like it buried down below the intake manifold in your picture.
It has to be near the side of the engine as it is driven by the timing belt. _________________ .ssS! |
Posted: Wed Oct 17, 2018 8:36 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
The pump is on the rear of the five cyl. engine. It's driven off the camshaft with a very short timing belt. It should reside just below and to the left of the coolant reservoir--near the radiator fan. You probably need to get the grille into the service position (pulled forward and away from the engine.) in order to access the pump. _________________ Casey--
y u rune klassik? |
Posted: Wed Oct 17, 2018 10:37 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
I "think" this must be the distribution pump.
Yes?
From Below:
From above:
Now, where is that Solenoid?
and where would I test for voltage? |
Posted: Wed Oct 17, 2018 10:39 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
Yes, that's your IP.
The shut off solenoid is on top of that rust colored square section of your pump that the injection lines come out of.
This is from a TDI but the solenoid is the same.
It's possible that the drive belt for the IP broke. While most people replace timing belts for the cam/crank, very few know to replace the IP drive belt or that it even exists.
Get a 17mm open end wrench & loosen one of the pipe union nuts, either on the injector end or the IP end (whichever is easiest for you to get to) and have someone crank the engine.
If fuel spurts out while cranking, then your problems are elsewhere. If nothing comes out, then the solenoid is bad or the IP drive belt has broken/stripped. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Oct 17, 2018 11:57 am Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
READ ALL THESE!!
1 You can test this without any tools by listening/feeling for the click of the solenoid when the ignition goes on. The definitive way is to test for 12V on the very top of that electrical connection - don't let the lead touch any metal anywhere else or you will pop a fuse.
2 Find the source of that oil on the pump - where its dark black. I think that is engine oil from somewhere else, if it is diesel, that might be your problem
3 YOU NEED TO BE REALLY CAREFUL AROUND DIESEL INJECTORS.
If you accidentally spray diesel into your skin, the medical treatment is to amputate. _________________ .ssS! |
Posted: Wed Oct 17, 2018 12:05 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
I loosened 3 of the injector line nuts and on cranking it fuel did gurgle out.
So, can I conclude that A) the solenoid is good and B) I am getting fuel?
iif so, next steps? |
Posted: Wed Oct 17, 2018 12:23 pm Post subject: Re: 1995 2.4L diesel T4 Transporter does not start |
It should be far more than a gurgle while cranking, were talking money shot. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
