ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sat Oct 06, 2018 10:46 pm Post subject: What goes in these holes? |
I'm putting back together my engine and while it's out and everything is easy to get to I want to make sure I have all the little odds and ends installed.
Most holes are in the engine tin.
On this side of the firewall tin, the smaller hole is for the fuel pressure regulator. What's the larger hole for (wires)? What are the two brackets for below it?
I'm guessing this large hole in the center is for the accelerator cable? Is there supposed to be a grommet there? Below that on the corner of the 1&2 tin, you can kind of see another hole, what goes there?
Again on the firewall tin above the temp sensor, is this another wire hole? Do you have a part # for that grommet?
There is a tiny hole on the 3&4 tin, I'm guessing that was once where the temp sensor wire came out? On the block there is a screw hole which looks like it would be to secure the engine tin but the hole is too big for a standard cheese head screw.
There are three holes here, I assume one is for the thermostat cable (do I have it in the right one?), what about the other two?
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
crownline Samba Member
Joined: September 10, 2010 Posts: 589 Location: Northwoods of WI
Posted: Sun Oct 07, 2018 8:28 am Post subject: Re: What goes in these holes? |
Do you have a Bentley green manual? It shows all the connections from the pre-heat to the brake vacuum line to fuel line and battery cables. That should cover most of the holes in question. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun Oct 07, 2018 8:43 am Post subject: Re: What goes in these holes? |
Just throwing this out there... no real way for me to check today. But ~ is it possible you have Vanagon tin? I see a hole near your Aux Air Reg valve that is for the Vanagon dipstick. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Oct 07, 2018 8:49 am Post subject: Re: What goes in these holes? |
All type 4 tin has that dipstick hole, it's a carryover from the sedan.
1st pic is alternator harness.
2nd pic is throttle cable, grommet is NLA AFAIK.
3rd is brake vacuum line (I think)
4th is plug wire clip
5th is dipstick (not used on bus), screw for lower deflector and thermo cable
Looking good in there _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Oct 07, 2018 10:26 am Post subject: Re: What goes in these holes? |
Assuming the one screw hole in the block has been drilled and tapped oversize, you will just need to use trial and error to see what the threads are.
I am guessing you are missing the right rear tin that covers the back of the #2 cylinder as I don't see it peeking out and the screw that holds it to the right side cylinder tin is missing. There is also a small seal that goes around the thermostat cable where it goes through the tin. You can make one out of plastic cut from a gallon oil jug. As I just suggested in another thread buy you oil for you next oil change in a black jug so you will have black plastic to make hole covers for your tin. |
Posted: Sun Oct 07, 2018 11:11 am Post subject: Re: What goes in these holes? |
crownline wrote: |
Do you have a Bentley green manual? It shows all the connections from the pre-heat to the brake vacuum line to fuel line and battery cables. That should cover most of the holes in question. |
I do have the Bentley and I couldn't find any pics that showed what went through any of these holes. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 11:45 am Post subject: Re: What goes in these holes? |
busdaddy wrote: |
Looking good in there |
Thanks
1) I'm guessing I would use a similar boot like the two that go through the alternator cover and cylinder tin.
What about the two brackets? Was something supposed to be screwed to it from the back side? Is it one of the heater tubes?
2) Do you recall what it looked like? Did the grommet have a tiny hole for the cable or was it a larger hole?
3) ...
4) Have you ever seen a photo in the gallery that shows its use?
5) I don't see any tin below it unless it supposed to be the very bottom air deflecting tin, which I haven't installed yet. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 11:53 am Post subject: Re: What goes in these holes? |
Wildthings wrote: |
It seems odd that someone would go through the trouble to tap the hole in the block and install a threaded insert but not install a threaded insert that would allow it to use the correct size screw.
The only tins I don't have installed is the very bottom air deflection tins. The rear/front tins are fully attached and all holes in those tins have a screw in them.
I assume the fact that you are recommending me to make the seal that it's no longer available?
Thanks _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 11:55 am Post subject: Re: What goes in these holes? |
Oh I almost forgot to ask!
On the block there is a large hole that exposes the flywheel, is that supposed to be covered?
Upper right corner.
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 12:18 pm Post subject: Re: What goes in these holes? |
It is the access hole for the bolts that attach the torque converter to the flex plate if you have an automatic tranny. There would have originally been a plug blocking off the hole. Many are missing, but I think they are still available. |
Posted: Sun Oct 07, 2018 12:23 pm Post subject: Re: What goes in these holes? |
ivwshane wrote: |
busdaddy wrote: |
Thanks
3) ...
5) I don't see any tin below it unless it supposed to be the very bottom air deflecting tin, which I haven't installed yet. |
1= Yes.
2= see pic below
4= https://www.thesamba.com/vw/forum/viewtopic.php?t=683593&highlight=ignition+clip
5= the top of #32 in the pic below has a threaded hole for a screw from the top there.
*6= https://www.thesamba.com/vw/forum/viewtopic.php?t=625677&highlight=converter+plug
Слава Україні! |
Posted: Sun Oct 07, 2018 12:32 pm Post subject: Re: What goes in these holes? |
ivwshane wrote: |
Wildthings wrote: |
It seems odd that someone would go through the trouble to tap the hole in the block and install a threaded insert but not install a threaded insert that would allow it to use the correct size screw. |
If it's a late carbed block (and maybe early FI too) it may have had the 8mm hole for the EGR thermal valve there, but as WT's says find a screw that fits. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Oct 07, 2018 2:17 pm Post subject: Re: What goes in these holes? |
busdaddy wrote: |
ivwshane wrote: |
busdaddy wrote: |
Thanks
3) ...
1= Yes.
2= see pic below
Thanks for the links, they helped alot.
Here is a better shot of that tin #32.
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 2:59 pm Post subject: Re: What goes in these holes? |
ivwshane wrote: |
[Here is a better shot of that tin #32. |
No, not that one, the one against the back of cyl #2 (I might have the tin number wrong), the top of it uses one of those holes beside the unused dipstick hole.
It's odd that we can see fins on whatever number that is you have on the front side of #1, sure it goes there? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Oct 07, 2018 4:33 pm Post subject: Re: What goes in these holes? |
ivwshane wrote: |
#32 is the right rear tin as the engine sits in the car.
Looks like you are missing a screw here as well though I can't see the threaded hole it is supposed to screw into.
You can see that your right front tin has been butchered and should be replaced before running the engine in hot weather.
It is a PITA getting you tin right when others have brutalized it, but once it is right it will stay right. |
Posted: Sun Oct 07, 2018 5:31 pm Post subject: Re: What goes in these holes? |
Alrighty!!!!! That f@cken sucked!
So I did forget to install the rear lower cylinder tin (as you correctly called -thank you) and that was a major set back. I'm so mad at myself for doing something so stupid. I wasted so much time today just to get it back in (its like the 3rd, 4th piece that has to go on).
As for the other butchared tin...g@d damn it! Ugh!
Better now then finding out later, right?
Thanks again. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 5:45 pm Post subject: Re: What goes in these holes? |
So here is that butchered tin removed. It looks like it's #27.
69 ghia coup 1600dp
70 single cab |
Posted: Sun Oct 07, 2018 6:02 pm Post subject: Re: What goes in these holes? |
Hmmm.., looks like VW made it that way, it's been a year+ since I dressed a late type 4, maybe that opening is covered by the lower sled tin when it's installed? Here's another from the other side, looks like it's missing the same corner: https://www.thesamba.com/vw/classifieds/detail.php?id=1605148
Either way it's good you asked about the hole near the breather, that tin missing would have been not so good. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Oct 07, 2018 6:04 pm Post subject: Re: What goes in these holes? |
no. that piece is hacked. there is metal missing and there should be a welded nut for a tin screw for connecting the upper and lower tin in that missing chunk (see pic below).
on another note, you're not using the correct tin screws and washers.
tin is supposed to look like this:
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sun Oct 07, 2018 6:39 pm Post subject: Re: What goes in these holes? |
What do you mean I'm not using the correct tin screws? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
