hylomatt Samba Member
Posted: Mon Oct 08, 2018 5:57 am Post subject: Early bay cooling air exit path |
is it normal that the escaping hot cooling air blows directly onto the mustache bar or is there supposed to be a deflector in place that I'm missing? When running, the cooling air blows over the cylinders and heads and then exits the rear of the engine right onto the mustache bar which I think assists with heating up the rear apron in the engine compartment. one might think it's the correct path because it could also assist in cooling the exhaust but the mustache bar stands in the way of that air reaching the muffler and doing that supposed job.[/list] |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Oct 08, 2018 6:50 am Post subject: Re: Early bay cooling air exit path |
Yes, that is how they came from factory. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Mon Oct 08, 2018 7:29 am Post subject: Re: Early bay cooling air exit path |
On a Type 4 engine the waste cooling air also blows across the oil filter. Apparently VW did not view this as a problem. In the hottest weather of summer consider running a synthetic or straight weight oils as they can handle higher temps than a typical dino multigrade oil. |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Mon Oct 08, 2018 11:09 am Post subject: Re: Early bay cooling air exit path |
Looks like you may be over thinking it a little. Don't. That's how it is. how it's always been. if your bus is running hot I would look elsewhere. the rear apron getting a little hot on an early bay is normal. Especially when running aftermarket or performance exhaust systems. much less with stock exhaust. Cool air comes in through the intake vents at the top and the warm air exits out the bottom. This is why a sealed compartment is essential.
My dos centavos. |
