zabo Samba Member
Posted: Mon Oct 08, 2018 7:42 am Post subject: new trw steering box troubles |
I installed a new trw box in my 60 a few weeks ago along with the required new pitman arm.
It drives fine bUt the steering wheel keeps changing positions. I had it centered correctly. Then after driving about 20 miles I parked. When i started driving again the wheel is at 5oclock position when going straight.
Yesterday a went back through everything, made sure all the bolts were tight, steering column aligned etc.. Thought all was good but then it did it again this morning.
If i turn the steering all the way to full stop it will move the wheel position.
maybe the shaft is slipping at the connection below the coupler?
Straight/Straight:
_________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
zabo Samba Member
Posted: Mon Oct 08, 2018 8:23 am Post subject: Re: new trw steering box troubles |
Thanks- I've read that and a lot other threads about these boxes but i didnt see anything that addressed the problem i am having. _________________ 1960 6 volt sedan- 1978 adventurewagen
Zundfolge1432 Samba Member
Posted: Mon Oct 08, 2018 8:38 am Post subject: Re: new trw steering box troubles |
Oh boy here we go again |
bluebus86 Banned
Posted: Mon Oct 08, 2018 8:54 am Post subject: Re: new trw steering box troubles |
zabo wrote: |
Straight/Straight:
I would stop driving the Bug until this problem is resolved, what ever is causing the wheel to change positions, may create a very dangerous driving condition. Do not drive until fixed.
Good Luck
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Oct 08, 2018 11:07 am Post subject: Re: new trw steering box troubles |
I would mark or scribe matching marks on everything that can loosen or change in the steering train (coupler, pitman arm, beam) and the clamps that hold them together. Then move the wheel until you feel it shift, and re-check your marks. There isn't much inside the box that would cause your symptoms, so I'd check the externals as above first. |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Mon Oct 08, 2018 11:13 am Post subject: Re: new trw steering box troubles |
Agree with the above.
Is the Pitman arm correct for the box (not necessarily for your year model) and not chewed out already at the connection? |
zabo Samba Member
Posted: Mon Oct 08, 2018 11:39 am Post subject: Re: new trw steering box troubles |
KTPhil wrote: |
good idea- ill try this _________________ 1960 6 volt sedan- 1978 adventurewagen
KTPhil Samba Member
Posted: Mon Oct 08, 2018 11:43 am Post subject: Re: new trw steering box troubles |
I've also seen use of blue painters tape, placed tightly at joints, a fine line made, and then it is slit at the joint where movement could occur, so any movement can be witnessed. It also allows for multiple checks-- after a couple of iterations, keeping scribe marks clear gets harder. This is removable for another try. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Oct 08, 2018 12:21 pm Post subject: Re: new trw steering box troubles |
Does the steering wheel position to 70clock if the wheel is turned to lock in the opposite direction? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Tue Oct 09, 2018 5:30 am Post subject: Re: new trw steering box troubles |
check your tie rod ends, ball joints and wheel bearings...... I have installed at least 6 or more TRW boxes with no issues.....One in my 65 bug that I have put 30K miles on. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Oct 09, 2018 5:35 am Post subject: Re: new trw steering box troubles |
I’m guessing he may have the wrong pitman arm. I had a similar issue on my dune buggy. Someone replaced the PA with a chrome unit. There are ones with small and large holes. When buying tierods you have to make sure they match. If the pitman arm has large holes and the tierods are small hole, you get a similar effect. Or at least I did. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Oct 10, 2018 6:47 am Post subject: Re: new trw steering box troubles |
Very good point - yeah, you need to mix and match tie rod ends if a later pitman arm. _________________ D-Dubya Manx clone - 63 Short pan,1914.
zabo Samba Member
Posted: Fri Oct 12, 2018 2:00 pm Post subject: Re: new trw steering box troubles |
Im going to take a closer look this weekend. All the rain this week has made it tough to investigate.
I think I have the correct pitman arm -except i hate that its chrome
https://www.ebay.com/itm/142807439743
"The pitman arm is to be used with a steering box with a small shaft and small king pin tie rods" _________________ 1960 6 volt sedan- 1978 adventurewagen
zabo Samba Member
Posted: Sun Oct 14, 2018 7:02 am Post subject: Re: new trw steering box troubles |
going to test some more- but made some scribe marks and drove it around the block - steering wheel changed position but scribe marks are still aligned.
I do think I need a new inner right wheel bearing as i can feel some play there. No play at the link pins. all tie rod ends are looking good.
Could the wheel bearing be effecting it this much? _________________ 1960 6 volt sedan- 1978 adventurewagen
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sun Oct 14, 2018 9:01 am Post subject: Re: new trw steering box troubles |
In the 60s, there were just two size of steering output shafts, so if yours fits, it's right.
So you have then verified that both sides of the steering coupler are not shifting? I have seen it where either of the clamps were not tight enough and that would cause odd shifts in the steering wheel. _________________ Andy T.
mukluk Samba Member
Posted: Sun Oct 14, 2018 1:19 pm Post subject: Re: new trw steering box troubles |
Are you also certain the steering box isn't shifting position on the torsion beam? _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil Samba Member
Posted: Sun Oct 14, 2018 1:24 pm Post subject: Re: new trw steering box troubles |
mukluk wrote: |
Are you also certain the steering box isn't shifting position on the torsion beam? |
This is my theory; in fact I had the exact same thing happen on mine about a year after I replaced the box. Scared the crap out of me since I was driving a twisty side road at the time. I drove VERY carefully home, and found the box slightly loose... it took some leverage to move it, but the torque spec showed it was in fact loose.
I just can't think of much internal to the box that could cause this. I'm not saying it's impossible (broken shaft inside?) but very unlikely. |
Posted: Sun Oct 14, 2018 4:17 pm Post subject: Re: new trw steering box troubles |
Well, don't original beams have a nub for the steering box clamp plate to slot into, preventing any kind of that sort of movement? When I put a replacement new Mexican made beam in my Baja I was a bit annoyed that it didn't have the alignment nub on it. _________________ Andy T.
TYBUGGER Samba Member
Joined: August 23, 2015 Posts: 28 Location: Long Island New York
Posted: Sun Oct 14, 2018 4:37 pm Post subject: Re: new trw steering box troubles |
I’m sorry to hijack this thread , but I just bought a trw sterring box and no instuctions came with it. Do you have to install any gear oil to it out of the box or grease it in any way. I’ve search threads but found nothing . Thanks for any help |
