dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Mon Oct 22, 2018 10:04 am Post subject: Re: 86 Vanagon stuck in 3rd |
How lucky am I? Decided to reseal my syncro transaxle and found a cracked low gear housing, so figured now was the time to check my 3/4 slider. It shifted fine prior to being removed. It just leaked a lot. I just pressed the shafts out of the gear carrier and was laying them on the bench next to the press and the 3/4 slider fell apart. I uploaded these two pictures of the broken slider. It broke exactly where the predicted failure occurs.
_________________ ☮️ |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Mon Oct 22, 2018 1:48 pm Post subject: Re: 86 Vanagon stuck in 3rd |
MarkWard wrote: |
How lucky am I? |
Good day to buy that Mega Millions ticket, Mark! _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Oct 22, 2018 3:46 pm Post subject: Re: 86 Vanagon stuck in 3rd |
Wow!
Great catch!
Looks like it started from the inside corners on 2 of the notches, geesh. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4789 Location: Bemidji, MN
Posted: Tue Oct 23, 2018 4:44 am Post subject: Re: 86 Vanagon stuck in 3rd |
wow, Mark!!! nice catch. incredible timing.
how many miles on this trans and was the slider OEM? _________________ -dan
www.thefixitworkshop.com |
Posted: Tue Oct 23, 2018 5:52 am Post subject: Re: 86 Vanagon stuck in 3rd |
It has the original square cutouts and the main shaft bearing cover, so I assume original. I'm not near the cluster, but I remember it being over 200k miles.
edit: correction 180,000 miles on the speedo head. I just checked. _________________ ☮️ |
JealousJack Samba Member
Joined: August 10, 2016 Posts: 130 Location: Vancouver
Posted: Sat Jan 11, 2020 1:06 am Post subject: Re: 86 Vanagon stuck in 3rd |
I never did update this. I did end up replacing my transmission from one I found in California. I suppose that somebody could have guessed that based on my topics further on, but I figured for anyone searching threads, yes! It was absolutely the transmission. Second time taking it out and putting it back in and I must say that I couldn’t do it without the Samba.
Thanks again guys. |
