Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Wed Oct 10, 2018 1:53 am Post subject: Transmission side cover replacement |
I pulled the '68 transmission out of my '56 Beetle to fix some leaks. I discovered after I cleaned all the grease and grime from the case the diff side covers are pretty corroded...
I'd like to replace the side covers. If I do this, will this effect the ring & pinion back lash setting or are all side covers of the same part number the exact same? _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
pnw1302 Samba Member
Posted: Wed Oct 10, 2018 5:20 am Post subject: Re: Corroded transmission side covers |
one of the other members will have a better answer, but as I recall side bearing preload is set by stacking gaskets between the case and the side cover. if you replace the cover, you should have the ability to check preload |
Joey Samba Member
Posted: Wed Oct 10, 2018 2:26 pm Post subject: Re: Corroded transmission side covers |
I thought the gasket stacking was for the axle flange. All the differential side covers I've removed only ever had one gasket. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu Oct 11, 2018 5:56 am Post subject: Re: Corroded transmission side covers |
Joey wrote: |
I thought the gasket stacking was for the axle flange. All the differential side covers I've removed only ever had one gasket. |
Yes, the stacking is for the axle tube. If it’s a 68 trans, the sidecover should only have an o-ring. VW was pretty good at making interchangeable identical parts, so a side cover with the same part number “should” be the same. Regardless, you still would want to check the preload, and backlash to make 100% sure. The real problem becomes having the correct shims to reset the measurements if things do change. The bearing preload you could check with a feeler gauge under the sidecover when loosened, but you’ll need something to slip in the diff to have a point of reference to check the backlash with a dial indicator. IMO, take it to someone that does trans work. |
