rjlatherow Samba Member
Joined: January 12, 2005 Posts: 135 Location: Tarpon Springs
Posted: Wed Oct 10, 2018 11:06 am Post subject: Cargo (flourescent) light wiring harness? |
Anyone have a clue how this is routed? I had no light, and when I checked the voltage I was shocked to find that there is no voltage and continuity between the 2 wires. Obviously they are screwed up somewhere - just don't know where to start looking without pulling the headliner.
Edit: I forgot to mention that I have a 2002 MV - no poptop.
Thanks!
-rj _________________ -----------------------------
<---- My sad, sad avatar is my perfect 1970 Squareback on fire - 1/1/05. Magnesium burns really pretty. Use a full trailer.
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Wed Oct 10, 2018 11:10 am Post subject: Re: Cargo (flourescent) light wiringt harness? |
Under the driver's seat, there is a auxiliary battery, a relay, and some fuses that power the lights in the rear cabin. the front kick panel drops down if you insert a screwdriver in the two slots in the face of it to release its tabs. All these components must be in working order to have power in the back. Could have a blown fuse, could have a bad relay, probably have a dead Aux battery. |
Posted: Wed Oct 10, 2018 11:18 am Post subject: Re: Cargo (flourescent) light wiring harness? |
Ah, I forgot the essential part! I have a MV, not a weekender and not a camper. Under my drivers seat is a weird empty space with nothing- no fuses. Well, a gum wrapper, but I threw that away-
<---- My sad, sad avatar is my perfect 1970 Squareback on fire - 1/1/05. Magnesium burns really pretty. Use a full trailer. |
