Trike Ike Samba Member
Posted: Wed Oct 10, 2018 4:08 pm Post subject: Start with a new case they told me. Did I listen? |
Starting over.
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Wed Oct 10, 2018 4:10 pm Post subject: Re: Start with a new case they told me. Did I listen? |
What happened?
Looks like a stroker engine? _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
Dale M. Samba Member
Posted: Wed Oct 10, 2018 4:28 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Ouch...
Also looks like the attack of the green slime...There is about 10x the amount there that is actually needed, hope you don't use that much on new case....
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Oct 10, 2018 4:41 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Look on the bright side, now you will have a new case.
The real dilemma is what caused your failure.
I’m putting a 2276 together for my Ghia and even though I’ve built quite a few performance VW engines in my day, I still pucker up every time I start one for the first time.
vilihardrada Samba Member
Joined: September 12, 2012 Posts: 34 Location: ariel,wa
Posted: Wed Oct 10, 2018 4:47 pm Post subject: Re: Start with a new case they told me. Did I listen? |
And is the crank still straight! |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Wed Oct 10, 2018 4:59 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Whats that white stuff on case parting line? _________________ "Albatross"! |
modok Samba Member
Posted: Wed Oct 10, 2018 5:02 pm Post subject: Re: Start with a new case they told me. Did I listen? |
If you started with a new case....
wouldn't' you just have a new case with a hole it?
I don't know. You don't have to say if you don't want to. We've all done it, although sometimes you can shut it off sooner and avoid the actual hole. |
Type 5 Joe Banned
Posted: Wed Oct 10, 2018 5:50 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Did it break a rod bolt?
Looks like the case was clearanced but the rods were not.
Hopefully he wasn't running "0" deck height... Or "0" deck height with copper heads gaskets like some would recommend. Bad Idea. _________________ If you would like to contact me, just email through one of my ads on here...
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Wed Oct 10, 2018 7:13 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Years ago I had a 1776 that had a lifter bore break and the lifter got sent out of the case, it made a hole that looked very close to that. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Oct 10, 2018 8:07 pm Post subject: Re: Start with a new case they told me. Did I listen? |
I don't understand. Are you saying the new case would have contained a broken rod? |
Posted: Wed Oct 10, 2018 8:15 pm Post subject: Re: Start with a new case they told me. Did I listen? |
The hole is the old case ( short block ) I reused due to financial shortage. It was a single port 1300cc to start. Single relief. New 85.5 pistons, heads new dual port stock. Dual IDF.
I knew better than to upgrade but I did, and it broke a rod soon after. And ruined my case, the rod and number two piston. Also split the cam in half.
The new short block was built for me. The white stuff in the case halves is high temp silicone, I hope. I also ordered new pistons and cylinders. Its 1600cc with a engle 100 cam and I still want to use the Weber IDF.
It's for a trike I've been riding for 10 years
modok Samba Member
Posted: Wed Oct 10, 2018 8:21 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Three Bond makes several kinds of white silicone flange sealant. |
Posted: Wed Oct 10, 2018 8:22 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Hey Modok, I was hot rodding. I was deep down sub conciousness wanting a new short block so everything was new. I was high speed on the freeway. I heard a knocking after a slight loss in power and then it stopped as I revved it faster. So I kept going shortly after it lo nicked again and then clicked and let out its last gasp in the form of o puff of white smoke. "I should have" is my new best friend along with hindsight. |
Posted: Wed Oct 10, 2018 8:53 pm Post subject: Re: Start with a new case they told me. Did I listen? |
I used the green goo " curil t " on the cylinder to case because I did a lot of reading. It is supposed to expand with the engine and not harden so I thought. Should I use "ultra black" instead? I did also use valve lapping compound to rub the new cylinder to the new heads, cleaned after, so nothing was between the heads and cylinders. |
modok Samba Member
Posted: Wed Oct 10, 2018 8:56 pm Post subject: Re: Start with a new case they told me. Did I listen? |
Trike on the highway.. yeah I see, bit of wind noise? Can't hear well.
usually what happens, after it starts going south you can hear it, but then if it gets quieter you think that maybne it's not so bad?, but, why did it get quieter?... the 2 bearings shells climb on top of one another and then it grabs solid and explodes |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Oct 10, 2018 9:38 pm Post subject: Re: Start with a new case they told me. Did I listen? |
modok wrote: |
Yeah, you got lucky! The new case would not have prevented a rod problem, you'd just be buying your 2nd new case... think of the money you saved! Now imagine you'd bought a TF-1 case first...you've saved even more!!
Loosing the new case would have just added insult to injury... |
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 256 Location: Peoria, Illinois
Posted: Thu Oct 11, 2018 6:43 am Post subject: Re: Start with a new case they told me. Did I listen? |
Sorry for your bad luck. Really like your trike. Very sharp. What did you use for a frame? |
Chip Samba Member
Posted: Thu Oct 11, 2018 7:04 am Post subject: Re: Start with a new case they told me. Did I listen? |
Type 5 Joe wrote: |
Hopefully he wasn't running "0" deck height... Or "0" deck height with copper heads gaskets like some would recommend. Bad Idea. |
Gonna have to explain yourself here... clearance is clearance. 0 deck is not clearance. But adding a copper shim at the top will get the same clearance as adding a shim at the bottom. You have to make sure that piece of copper doesn't have a smaller ID than the cylinder. Coppers work just fine. Plenty of us doing it successfully. |
Posted: Thu Oct 11, 2018 8:56 am Post subject: Re: Start with a new case they told me. Did I listen? |
Hey guys, I'm posting pics but they aren't in proper order. The case that has the hole is 1300cc upgraded to 1600cc dual port dual carb. The painted blue engine is that engine that failed due to not splitting the case and installing new bearings and pressure relief valve.
The broken case was on my bench. Picture taken.
Then I ordered a new short block. Dual reliefs AS41. Which is the plastic wrapped and then on my bench. I building the new one now.
I'm sure it will be great now that I have a solid base to build on.
Modok take a look at these, you described it well.
The new case is on my bench own as I type. I just installed dual port 8mm head studs with ultra black sealer. It has case savers.
My heads are new stock dual port 51cc chamber.
this is my new short block. |
Type 5 Joe Banned
Posted: Thu Oct 11, 2018 9:06 am Post subject: Re: Start with a new case they told me. Did I listen? |
Hey Chip,
That is exactly it... But clearance is indeed clearance.
When you clearance the inside of a case... You give a little extra room for a rod bearing failure. At least .040" - .060" That way if there is a problem you don't slam the case.
Deck is the same... If you run "0" deck, and you spin a bearing, or if the bearing shells double up... The piston will slap the head.
If your turning 6000 RPM, the piston will hit the head at least a couple thousand times before you can shut it off.
I had a guy bring in his engine that did this... The piston shattered and a chunk got between the rod and the case (and lifter bores)... Exploded the engine.
-And yes, the copper "head gaskets" are not made precision along with most off-the-shelf bored heads (sloppy) to register exactly on center with piston clearance if needed.
Copper head gaskets are crap in my opinion... Glad you are having "good luck" with them. _________________ If you would like to contact me, just email through one of my ads on here...
