terryly Samba Member
Posted: Wed Oct 10, 2018 9:30 pm Post subject: Thermostat what would you do ? |
Hello looking for a little input on which Thermostat to run. Seems I poked a hole in my Awesome powder-coat thermostat Probly backing over a bush or something. So now I am in the market for another. Would you run the 36hp thermostat that opens 75-80* or the fuel injected one that opens at 80-85*. both are the same price and delivery time. Previously I was using the 36hp 75-80* stat. Its in a street legal off road Baja bug with no apron.
Why did VW use a warmer thermostat for fuel injected motors ? do other cars use a warmer stat?
Motor is 2180 cc
MS3PRO running ITB algorithm
dual Idf throttle bodies
cam sync
sequential fuel/spark
stock weight fly wheel
Cb cnc los ponchito 42x35 valved heads
beehive springs
Web cam 86a cam (actually web cam reground vw blank to porsche 912 specs) thanks Dan working great
Udo Becker lifters
all hoover mods
30mm triple o-ring oil pump
Porsche piston sprayers
push rod sprayers
9.6 - 1 compression
Any thoughts or input will be appreciated
Thanks
Terry
Here is some pics for your amusement
buttoning up motor
fitting in the car
car running great after some test and tune
the future planning I did this before tear down Replaced case, piston sprayers, pushrod sprayers 86a cam heavier fly wheel.
Going to be a higher compression- lower boost Water/meth injected air/water intercooled motor
(wow isn't that a mouthful )
_________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Calgary Alberta Canada
Terry Lytle |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Thu Oct 11, 2018 2:02 am Post subject: Re: Thermostat what would you do ? |
80-85* _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7220 Location: Videbaek Denmark
Posted: Thu Oct 11, 2018 4:08 am Post subject: Re: Thermostat what would you do ? |
X2
F.i engines generally run a little cooler. So they could use a little help keeping temps up under part load |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Oct 11, 2018 5:39 am Post subject: Re: Thermostat what would you do ? |
a true 36hp thermostat is 65*
a 40hp-1600 non FI thermostat is 65*-70*
a Type 1 FI thermostat is 80*-85*
Type 4 is 85*-90*
there are several other temp range bellows type thermostats used on Type 3, Porsche 356/912. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Thu Oct 11, 2018 10:24 am Post subject: Re: Thermostat what would you do ? |
One theory is that FI came on board at about the time emissions regulations got tighter, and emissions testing included the warmup period. A thermostat with a higher rating would warm up the motor faster, which helped them pass the emission testing, since a hot engine burns gas more thoroughly.
A secondary effect is in really cold weather, to keep the engine hot for low emissions. |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Thu Oct 11, 2018 12:40 pm Post subject: Re: Thermostat what would you do ? |
You need sled tins to use a thermostat. I use EFI L Jet bug tins and made a little tab/bracket from the outer edge of the tin up to the head. An added benefit is the thermostat is protected as well as shrouded so it is bathed in air off the head so it can respond. _________________ Steve
Steve's 87 Syncro project |
Posted: Thu Oct 11, 2018 12:42 pm Post subject: Re: Thermostat what would you do ? |
This is a mexi thermostat but it works the same with a german style one.
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Thu Oct 11, 2018 1:29 pm Post subject: Re: Thermostat what would you do ? |
Steve Arndt wrote: |
Yikes! I've never trusted those things, I saw one fail closed, something leaked out of it. Looks like you have been using it some time, so I guess...works ok? Any others out there using those successfully?
Weren't there some Brazilian or Mexican engines delivered stock without the thermostat? |
Posted: Thu Oct 11, 2018 2:37 pm Post subject: Re: Thermostat what would you do ? |
I did not use the mexi stat long. It worked more digitally, open or closed. Not smooth and variable like the German design. My post was to show the sled tin. It is important to have air flow controlled around the thermostat. If it just hangs out in the open like on a baja with no tin, it will stay cold and not open. That is not good. It can also be damaged like the original POST was about. _________________ Steve
Posted: Thu Oct 11, 2018 5:21 pm Post subject: Re: Thermostat what would you do ? |
Hi Steve I was using sledtins and industrial tins a bush/stick must have poked in the back side, I was thinking of putting some expanded sheet metal or grate to try and keep most stuff from poking in the back side with out interrupting flow to much . Some times backing into or over stuff is unavoidable in the terian I visit hence the reason for the move to large side mirrors I would think the push rod tubes could be vulnerable as well. Thanks for your thoughts and insight
KTPhil some good info never really thought about emissions wonder if the warmer stats are a good thing from a performance point of view I live in a colder climate and often use this car during winter. I have a gas heater that when I get that installed and figured should make it more usable during nasty weather
udidwht Thank you sir for the recommendation I appricaiat that and am leaning that way
Alstrup a big thanks to you as well I regard you as one of the sharper characters around and will probly use the higher temp thermostat
hazetguy Thanks for the clarification I did not realize the type 4 has an even warmer opening temp I wonder why ? Same type of bellows as a type 1 ? _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Terry Lytle |
jason Samba Member
Posted: Fri Oct 12, 2018 12:32 pm Post subject: Re: Thermostat what would you do ? |
Are you using cool tins and sled tins? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Fri Oct 12, 2018 3:17 pm Post subject: Re: Thermostat what would you do ? |
jason wrote: |
That’s what I intend to do. Is there some little mystery in airflow that I’m unaware of? _________________ Volkswagen!
(Compression 8.7:1) |
KTPhil Samba Member
Posted: Fri Oct 12, 2018 4:35 pm Post subject: Re: Thermostat what would you do ? |
As has been posted many times, that design fails in the "flaps closed" position which is NOT desired! The original bellows designs fail with "flaps open" and are therefore safer.
I can't find the thread right now, but I think I saw a recent post that identified this "Mexican thermostat" as originally being intended only to operate the under-license-plate flap on late Mexican Beetles (to let more air into the engine bay), and NOT to operate the shroud flaps. However, it's been repurposed by some sellers as a flap control thermostat. Something to think about...
EDIT: Found thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=454938 |
Posted: Tue Oct 16, 2018 5:52 am Post subject: Re: Thermostat what would you do ? |
Hello Just thought I would close this thread out. I decided to go ahead and use the type 4 temp range thermostat 85*-90*. Went Ahead and orderd it from Clark at Awesome Powder coat as my old one really seemed like a quality product and its failing was no fault of its own. Thanks Clark
jason yes i am using cool tins and a industrial/sled tin combo
Thanks for everyone's input _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Terry Lytle |
rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Tue Oct 16, 2018 6:19 am Post subject: Re: Thermostat what would you do ? |
Luv that car. Did you get an initial map from someone or have a tuner set it up? |
mark tucker Samba Member
Posted: Tue Oct 16, 2018 12:33 pm Post subject: Re: Thermostat what would you do ? |
i dont use tham, IMHO no reason for them unless your in cold weather.and then I would rather make a restrictor for the air intake not devert it from certan parts letting other portions heat and some not so much. |
Posted: Tue Oct 16, 2018 12:48 pm Post subject: Re: Thermostat what would you do ? |
Get a filtered air-box set up as well. You're doing that engine a disservice by running without filters. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Tue Oct 16, 2018 12:58 pm Post subject: Re: Thermostat what would you do ? |
That's what's in the big canister with the maple leaf, looks big enough for a Cummins 12v filter.
I'm assuming you didn't look at all the pics? |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Tue Oct 16, 2018 1:42 pm Post subject: Re: Thermostat what would you do ? |
Ha ha... Yes, run an airfilter. Don't do a disservice.
Good choice on the thermostat. There would be some morons on here saying don't run one.
It helps if you understand how the whole thermostat system works. _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
Posted: Tue Oct 16, 2018 1:52 pm Post subject: Re: Thermostat what would you do ? |
rodeking wrote: |
... _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
