elpres Samba Member
Posted: Thu Oct 11, 2018 1:43 am Post subject: Clutch issue maybe |
Hi, I have just finished a top end rebuild and now I want to start up the engine on the floor. Therefore I put on the transmission. It all went ok, but I have a fear that there is something wrong with the new clutch assembly.
How much force would I need to apply to the clutch lever arm, to make it engage?? There is maybe 2-3cm freeplay, before the throw out bearing hits the fingers on the clutch plate.
The clutch is new and the flywheel came with the engine.
Could the flywheel depth be wrong? As I remember the depth was 21mm.
Any input would be great. First rebuild for me. _________________ Jakob |
elpres Samba Member
Posted: Thu Oct 11, 2018 1:55 am Post subject: Re: Clutch issue maybe |
To me the fingers look very flat?? _________________ Jakob |
airschooled Air-Schooled
Posted: Thu Oct 11, 2018 2:39 am Post subject: Re: Clutch issue maybe |
I have never been able to actuate that style of pressure plate by hand. (But occasionally can disengage the 3-arm early style..) Remember the clutch pedal has something like a 10x multiplier built into the pivot due to the pedal lever and clevis hook lengths.
As far as how far the diaphragm fingers stick out, did you measure the thickness of your clutch disc before installation?
www.airschooled.com |
elpres Samba Member
Posted: Thu Oct 11, 2018 4:27 am Post subject: Re: Clutch issue maybe |
asiab3 wrote: |
Robbie |
Thank you Robbie.
I have now pulled the trans, and will measure the different things so I know for sure that all is within specs.. I’ll be back. _________________ Jakob |
Posted: Thu Oct 11, 2018 5:48 am Post subject: Re: Clutch issue maybe |
The diaphragm fingers look just fine for a new clutch, they will rise up as the clutch wears and once they touch the cover many tens of thousands of miles down the road the clutch will be done for.
As said above you don't have much mechanical advantage to move the lever without the 10x multiplying factor of the clutch pedal. You could use a 12" Cresent Wrench to get it to move if you want. |
elpres Samba Member
Posted: Thu Oct 11, 2018 5:56 am Post subject: Re: Clutch issue maybe |
Wildthings wrote: |
Ok i see. Maybe i dident have to pull the tranny, as all seems in order.
The clutch disc itself measures 9mm, and if i measure the disc plate and the disc in total it’s 3mm thicker than the old assembly. So I guess it’s alright. !? _________________ Jakob |
Posted: Thu Oct 11, 2018 6:00 am Post subject: Re: Clutch issue maybe |
elpres wrote: |
Wildthings wrote: |
The clutch disc itself measures 9mm, and if i measure the disc plate and the disc in total it’s 3mm thicker than the old assembly. So I guess it’s alright. !? |
I think you are fine |
SGKent Samba Member
Posted: Thu Oct 11, 2018 7:35 am Post subject: Re: Clutch issue maybe |
you won't move it with your hands. It takes the leverage in the clutch pedal system. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
elpres Samba Member
Posted: Thu Oct 11, 2018 7:55 am Post subject: Re: Clutch issue maybe |
SGKent wrote: |
you won't move it with your hands. It takes the leverage in the clutch pedal system. |
When the tranny was on I took some pliers for leverage, and I managed to bent the arm a little bit... but I guess with the clutch cable it will be different. I hope... _________________ Jakob |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Thu Oct 11, 2018 8:36 am Post subject: Re: Clutch issue maybe |
So if one wanted to fire up an engine out of the vehicle, essentially you just need a bell housing to mount the starter. Couldn't you just leave out the disk and pressure plate for engine testing purposes? |
elpres Samba Member
Posted: Thu Oct 11, 2018 9:05 am Post subject: Re: Clutch issue maybe |
alaskadan wrote: |
I could, but I just found it easier to mount the tranny, as I don’t have a separate bellhousing. _________________ Jakob |
