74superTN Samba Member
Joined: April 01, 2007 Posts: 675 Location: Port Saint Lucie, FL
Posted: Fri Oct 12, 2018 9:29 am Post subject: Dual Weber 40's leak at Wide Open Throttle |
So my newly installed Weber 40's leak at wide open throttle. I'm running a 3.5psi fuel pump from CB Performance and that's also where the carbs came from. I checked the floats and their at 14mm which was what their paperwork recommends. Any ideas? It's a type IV motor _________________ 73 Thing
80 Vanagon Westy |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Fri Oct 12, 2018 10:36 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
Leak from where? |
How can you tell a carb is leaking at wide open throttle if the engine isn't on a test stand hooked to a dyno? |
Posted: Fri Oct 12, 2018 10:49 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
Leaking from the throttle shaft
Let me rephrase, I operate the throttle of the carbs while running with the engine lid off. I can slowly see fuel start to build up on the throttle shafts but only when the throttles are fully open. _________________ 73 Thing
80 Vanagon Westy |
SGKent Samba Member
Posted: Fri Oct 12, 2018 10:51 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
yes - leak where and is this motor running, or is it static? Is a fuel pump running? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Oct 12, 2018 11:05 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
Fuel pump running, 3.5 rotary from CB Performance
Engine is running and installed in the vehicle
I have the deck lid off from up top and i'm moving the throttles by hand _________________ 73 Thing
80 Vanagon Westy |
SGKent Samba Member
Posted: Fri Oct 12, 2018 11:13 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
74superTN wrote: |
I have the deck lid off from up top and i'm moving the throttles by hand |
still didn't tell us where it is leaking _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Oct 12, 2018 11:18 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
from the throttle shaft, bottom center of the carb _________________ 73 Thing
80 Vanagon Westy |
Posted: Fri Oct 12, 2018 11:32 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
I am guessing this only happens on a cold engine? When hot the fuel will evaporate off the throttle plates and not have a chance to run through the throttle shaft bushing. It is pretty normal to see this on a cold non running engine.
Posted: Fri Oct 12, 2018 1:07 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
Bottom center and the shaft is getting wet my guess would be you are leaking from the accelerator pump cover and it is running onto the shaft.
Use a small mirror and flashlight to see where the fuel is leaking from.
Also should be able to remove the carb and with the bowl fuel cause it to leak by operating the throttle. |
Posted: Fri Oct 12, 2018 3:45 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
I don't know what the issue was but my mechanic told me I had my fuel pump located too close to the carbs so I moved it back by my fuel tank (Vanagon) and just drove about 30 minutes with no leaks..idk _________________ 73 Thing
80 Vanagon Westy |
Posted: Sun Oct 14, 2018 4:33 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
After further inspection, it looks like it only leaks a few minutes after I shut my engine down after a long drive. _________________ 73 Thing
80 Vanagon Westy |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sun Oct 14, 2018 12:21 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
What height were the floats set at?
We're you certain not to have depressed the ball when adjusting them?
Was the carb top gasket in place when this was done?
Fuel pressure?
You certain the air bleed ports aren't blocked? (carb top)
With the engine NOT running and your pumping the gas you will see fuel come from the carbs. The fuel must go somewhere and the most likely spot is the top of the butterfly then across the shaft.
Unless you plan on starting the engine stop pumping the pedal.
All carbs when bought new or used must be tore down and checked thoroughly. Always. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sun Oct 14, 2018 4:04 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
udidwht wrote: |
Fuel pressure?
All carbs when bought new or used must be tore down and checked thoroughly. Always. |
So i'm dumb, explain where the air bleed ports are? _________________ 73 Thing
80 Vanagon Westy |
Posted: Sun Oct 14, 2018 4:40 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
74superTN wrote: |
udidwht wrote: |
Fuel pressure?
So i'm dumb, explain where the air bleed ports are? |
The air bleed ports are the tiny openings in the carb top (main body) that allow air to be brought into the idle jet circuit to mix with the fuel.
In the 12th pic down in the 'Setting up your IDF's'. You can just see them on the left & right side of the fuel bowl above where the main stacks are screwed into.
You want to be certain that the gasket does not block/cover those ports.
And be very CAREFUL if you try to remove the brass pin that holds he float on. Do not remove it unless you need to replace the needle/seat. You do not want to break the aluminum boss on either side that holds the pin in place
https://www.rezrov.net/www.carburetorclinic.com/index.htm _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Mon Oct 15, 2018 4:51 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
ok thanks, I'll check those out! _________________ 73 Thing
80 Vanagon Westy |
Posted: Wed Jan 02, 2019 1:30 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
Update, issue fixed. I installed the Phenolic Insulators from Gansmann industries. Worked like a champ! _________________ 73 Thing
80 Vanagon Westy |
Posted: Wed Jan 02, 2019 3:06 pm Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
Between the carb and manifold? _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Thu Jan 03, 2019 4:34 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
udidwht wrote: |
Between the carb and manifold? |
Yep, between the top of manifold and the carb _________________ 73 Thing
80 Vanagon Westy |
Posted: Thu Jan 03, 2019 9:40 am Post subject: Re: Dual Weber 40's leak at Wide Open Throttle |
74superTN wrote: |
udidwht wrote: |
Yep, between the top of manifold and the carb |
Correct.
It's hit and miss if ones set up ends up needing a set on the manifolds. As for the fuel weep after shutdown (heat-soak related). This is more common than most realize. In fact, many don't don't but it's also not something to lose sleep over. With open air carb/s you will get fuel on the outside of them.
Be sure the lead plugs at the base of the carb are either tapped and threaded/plugged. Or JB Weld them. They will come loose overtime due to vibration. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
