1776 rebuilt problem
abcdleines
abcdleines is offline
PostPosted: Sat Oct 13, 2018 11:23 am    Post subject: 1776 rebuilt problem Reply with quote
Having trouble with 1&2 cylinders. Compression is over 120 all around. Carbs smell and look like there getting gas. Running Weber dual 44ís that were rejetted for the 1776cc. Carbs rebuilt when rejetted. Plugs are clean with no oil trace. Plug wires tested good too. A lot of smoke when start and the muffler exit on that side is spitting black oil, not thick oil, very runny. Idle screw on that carb doesnít seem to work either. 44ís to big even though they were rejetted? Also 3&4 side gets up to temp and hot to touch where as 1&2 are cool to touch. With all the trouble I have had restoring this Thing, fells like it just doesnít want to be on the road again, fights me all the time! Hope this forum can help. If another carb set up is better which one do you all recommend?Thanks.
HMVWNAB
HMVWNAB is offline
PostPosted: Sun Oct 14, 2018 8:53 am    Post subject: Re: 1776 rebuilt problem Reply with quote
Probably better responses in the Performance/Engine/Transmission Forum.
"Knowledge is good" Emil Faber
kenj06
kenj06 is offline
PostPosted: Sun Oct 14, 2018 7:14 pm    Post subject: Re: 1776 rebuilt problem Reply with quote
Sounds like 1/2 may be running rich. The 'black oil' may be carbon from running overly rich but usually your plugs would show that. Running rich would also cause it to be cooler that 3/4.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Oct 14, 2018 7:22 pm    Post subject: Re: 1776 rebuilt problem Reply with quote
Moved...
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2019
Danwvw
Danwvw is offline
PostPosted: Sun Oct 14, 2018 7:36 pm    Post subject: Re: 1776 rebuilt problem Reply with quote
I doubt Dual 44's will work on a 1776cc engine? What size are the venturi?
My 1971 Bus Engines: W-100 Cam, Webcam 118, Webcam 163 my current daily driver and Porsche 924S For Sale!
Pruneman99
Pruneman99 is offline
PostPosted: Sun Oct 14, 2018 7:50 pm    Post subject: Re: 1776 rebuilt problem Reply with quote
If this is a new engine ditch the 44's for now. Get a single carb and get the break in done.
vugbug68
vugbug68 is offline
PostPosted: Sun Oct 14, 2018 8:53 pm    Post subject: Re: 1776 rebuilt problem Reply with quote
I daily drove a 1776 with dual 44's with 36 vents for a while, It was a great engine, super smooth and would rev to 6k
71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin
Dauz
Dauz is offline
PostPosted: Sun Oct 14, 2018 8:54 pm    Post subject: Re: 1776 rebuilt problem Reply with quote
I had 44s on a 1776. After the hassle to get it right, I wouldn't do it again. 40s would be good.
mikedjames
mikedjames is offline
PostPosted: Mon Oct 15, 2018 10:09 am    Post subject: Re: 1776 rebuilt problem Reply with quote
Check the usual. Look to see if its dribbling fuel out of the carbs on 1/2 side because of fuel metering needle leaking and pouring gas from the the float chamber into the manifold..
Ancient vehicles and vessels
1974 VW T2 : Devon Eurovette camper with 1641 T1 engine, Progressive carb, full flow oil cooler
Engine 1: 40k miles (rocker shaft clip fell off), Engine 2: 30k miles (rebuild, dropped valve). Engine 3: a JK Preservation Parts "new" engine.
