xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2673 Location: East Nassau, NY
Posted: Mon Oct 15, 2018 7:29 am Post subject: Re: My air-cooled to 1.8t build |
Here's another picture you find useful, it shows AEB serpentine belt for turning only the alternator, you may be able to zoom in and see what the part number is of that belt.
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Mon Oct 15, 2018 7:42 am Post subject: Re: My air-cooled to 1.8t build |
xoo00oox wrote: |
It looks like that is a newer style 1.8t (possibly AWM) with an internal water pump. I still need to be able to drive my external water pump, so the setup in the photo you posted won't work for me. |
danfromsyr Samba Member
Posted: Mon Oct 15, 2018 7:53 am Post subject: Re: My air-cooled to 1.8t build |
indeed that's the later style
here's a great build (into a VW Rabbit) that shows the AEB Alt/Water pump only arrangement.
you have to modify the former belt driven fan mount.
this guy ended up with a 40x5rib belt
but iirc, I think mine is a 39.5x5 but what's a 1/2 right.
https://boostedrabbit.wordpress.com/page/2/
specifically https://boostedrabbit.wordpress.com/2010/08/01/serpentine-belt-setup/
Abscate wrote: |
Posted: Mon Oct 15, 2018 7:58 am Post subject: Re: My air-cooled to 1.8t build |
Oooopsy, you're right. Here's an AEB with only the coolant pump and the alternator being turned...
But, don't route yours like this or the coolant pump will spin the wrong way, do it the way Dan has shown. |
Posted: Mon Oct 15, 2018 8:32 am Post subject: Re: My air-cooled to 1.8t build |
Great information, thanks guys! I was aware of being able to use the VR6 water pump pulley, but wasn't sure what to do about the old belt driven fan clutch pulley situation. It seems as though he just took that big alternator/power steering/fan clutch bracket off the engine and cut off all the stuff he didn't need.
Also noted the belt lengths used. |
Vanagon Nut Samba Member
Posted: Mon Oct 15, 2018 10:11 am Post subject: Re: My air-cooled to 1.8t build |
revolution337 wrote: |
...... Also, did you space the transmission mount down at all? I've noticed others have done so and I'm not quite certain the pros/cons in doing so. Is it necessary in order to prevent too much of the engine sticking up above the deck lid?
This may not be relevant but if you're doing a 50º swap with the diesel Vanagon oil pan and plan to lower the engine at all......
On my 1988 Vanagon, I lowered the pulley end of my 50º ABA to allow the engine to clear the engine cover. [edit: That end of the engine may now be] lower than the stock diesel. IIRC the diesel tranny nose sits higher than the WBX or air cooled tranny which in turn lowers the engine at an angle. As such, this may not be a potential issue, but since I did not lower the WBX tranny nose, I'm curious if while climbing a steep grade with an engine low on oil, is there any real risk of the oil pump sucking air.
Neil.
My measurement methods were a little crude but these images give an idea of how much I lowered the pulley end of engine. AFAIK, OC of the air cooled crank pulley nut would be in a similar location. WBX Engine mounts were new at time of measurement.
stock diesel engine/tranny position
where my ABA crank is relative to old green tape mark. You can kind of see the tape
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Mon Oct 15, 2018 12:10 pm Post subject: Re: My air-cooled to 1.8t build |
I plan on running the AEB at 15* with this setup. But good info, non-the-less |
Posted: Mon Oct 15, 2018 12:26 pm Post subject: Re: My air-cooled to 1.8t build |
Cool.
You will enjoy having less of a bump in the engine cover. My ABA 15º engine cover has a ~ 4" tub.
VE7TBN |
Posted: Wed Nov 07, 2018 6:39 pm Post subject: Re: My air-cooled to 1.8t build |
Minor progress...got a bunch of new parts/gaskets/seals for the engine. Figure now is the time to do the work, when the engine is out and easy to work on!
Silicone crankcase breather lines to replace the crumbling original ones, courtesy of 034 Motorsports.
Aluminum coolant flange, replacing the often faulty plastic units
Also took this time to pull apart and rebuild the alternator.
Original brushes on top, new ones on bottom
Also, my clutch, flywheel, and adapter plate have all arrived from KEP! (sorry, no pictures of it at this time) |
Posted: Thu Nov 08, 2018 2:20 pm Post subject: Re: My air-cooled to 1.8t build |
Does anyone happen to have a source for the pinouts of the 5 colored engine harness-to-body plugs? I've found several different wiring diagrams for the engine harness and interior harness, but have been unable to find a diagram that specifically identifies all of the wiring within these 5 colored connectors.
I want to verify which wires are needed/not needed so I can trim away unnecessary wiring. The engine is from a '99 Passat AEB. |
Posted: Thu Nov 08, 2018 2:42 pm Post subject: Re: My air-cooled to 1.8t build |
Thanks Dan!
I've already read through all of Chris's 1.8t threads and saw his wiring diagrams. I also already have a copy of that engine wiring diagram you have referenced. I was more hoping to find a diagram or pin-out specifically of the body connectors, as opposed to the ECU connectors.
I don't think that diagram exists though lol. I just have to search through the other existing diagrams and piece it together myself. |
Posted: Thu Nov 08, 2018 2:51 pm Post subject: Re: My air-cooled to 1.8t build |
it's been a while for my swap, but shouldn't that be the connector column in the chart?
plus it's good to have these cross referenced for future 1.8T swap searches.
more bread crumbs more successes. _________________
Abscate wrote: |
Posted: Thu Nov 08, 2018 3:26 pm Post subject: Re: My air-cooled to 1.8t build |
danfromsyr wrote: |
more bread crumbs more successes. |
Yes that chart has several of the main necessary pins needed for the swap, but doesn’t not list every single wire within those connectors. That’s what I was looking for.
Anyway, no big deal. Just wanted to check if maybe I missed an OE diagram somewhere along the lines.
My engine is currently mostly stripped down to bare cylinder head and block. It’s getting a thorough cleaning and then I’ll be reinstalling all the accessories, along with new gaskets/seals. It’s getting harder to work in my unheated/uninsulated garage though lol. And it’s not even winter yet.....I need a better space heater.
Last edited by revolution337 on Thu Nov 08, 2018 3:28 pm; edited 1 time in total |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Tbob Samba Member
Joined: May 26, 2007 Posts: 417 Location: Pensacola, Fl.
Posted: Fri Nov 09, 2018 5:02 am Post subject: Re: My air-cooled to 1.8t build |
Saw your comment on the space heater, and thought I would share my experience heating garages in frozen spaces. My experience is with uninsulated 2 car garages in both in Chicago and in Southern Indiana, both frozen wastelands when it comes to working in the garage in winter. No 110 volt space heater will put out enough heat to really change the situation. As they are limited to 1500 watts of power consumed, they are just to small.Since they consume 1500 watts of power, almost 15 amps at 110 volts, you can't use more than one per 20 amp circuit safely. So using a bunch of then is not safe unless you have that same number of 20 anp circuits.
For years I used a Ready heater 35,000 BTU kerosene torpedo heater, and it took the edge off, but you had to keep the garage door open to allow it to vent, somewhat negating the effect in really cold weather.
About 10 years ago, I installed a 100,000 BTU furnace dedicated for the garage. When it is 20 degrees out, the furnace will heat the garage to 65-70 degrees, running efffectively full time. I only heat the garage when I an working out there to not spend too much on natural gas. It cannot heat it any hotter than 70 degrees.
The takeaway from this is, in my now non frozen opinion, is to use something that can add enough heat to counteract the heat loss, Uninsulated, no ceiling garage? You need more than little electric heaters to even take the chill off. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
Posted: Fri Nov 09, 2018 6:51 am Post subject: Re: My air-cooled to 1.8t build |
Ooo now we're talking garage heaters,
I have a large barn that's impracticable to heat all the air in, as it leaks out as fast as you heat it (convection ya know).
I use 2 radiant tank top propane heaters. one on each side of me and my work area.. the radiant is unaffected by air loss and heats the area/objects I am working on.
I do this effectively with 2x 15k btu of propane, they can go higher but to not much increase in comfort.
it does help that I have 4 20# propane bottles to make swapping out easier.
I get many many days of work per tank on the lower BTU. it's the red/infrared light that's heating ya. _________________
Abscate wrote: |
Posted: Fri Nov 09, 2018 11:29 am Post subject: Re: My air-cooled to 1.8t build |
All I have right now is an electric infrared heater hanging directly above where I do most of my work. It's enough to keep the edge off, so long as you don't move more than 5 feet away from underneath it.
I've also had some decent luck with a Big Buddy propane heater. Again, only when working within the same small vicinity though. |
Posted: Tue Nov 13, 2018 5:38 pm Post subject: Re: My air-cooled to 1.8t build |
More engine parts removed and cleaned...
Also modified the giant alternator/PS/fan clutch bracket so that I am able to run the VR6 water pump pulley without any issues. I do not currently have (or plan to add) power steering or A/C, so the belt will only be driving the water pump and alternator.
How it started
Halfway through cutting...
All finished cutting, photo shows the two pieces I removed from the bracket. I kept most of the unit, as it has mounting bolts for the water pump. The bracket also has a threaded hole that is used for a support rod for the intake manifold. I was able to retain both of these functions while eliminating the fan clutch hub and power steering bracket.
When I first picked up the Passat, I noticed a rattle on decal coming from the turbo area. I assumed it was from the waste gate flapper, and I was correct. It is very loose, and actually is starting to form a crack around its start. Also found several other cracks in the turbine housing. Looks like its time for a new turbo!
Now for questions. I am thinking of going the route of using long marine grade rubber hose for the coolant lines up to the radiator. My question for those who have done so, is there a particular size that fits best? I'm having the best luck locating 1.25" hose. I'm unable to find the O.D. measurements of the hose though, so I can't say if the two hoses will be able to fit through the holes in the van crossmember. Can anyone chime in with their experience? |
