pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sun Oct 14, 2018 9:40 am Post subject: Has anyone completed a Prius power conversion into a Vanagon? |
I've looked through several Samba threads, including "Vanagons in the future: alternate propulsion options" but other than a sharp yellow Doka with a tesla conversion, there are no examples in that one of complete or nearly complete conversion. And who has the cash to lay down for a cashed Tesla! There must be plenty of not-too-high mileage Prius wrecks nearly everywhere-- hasn't anyone tried to arrange such a marriage? Subie, our favorite gas power conversion doesn't make a highly fuel-efficient hybrid, but Honda and several other brands of hybrids are out there getting into crashes--why are there no conversions underway? I dream of a day when my Westie gets 32 or 34 mpg-- or better, with a plug-in hybrid set-up so city trips will be almost free. This 15-20 mpg stuff is so 1980s. |
vanlover22 Samba Member
Joined: August 02, 2009 Posts: 30 Location: Santa Cruz, CA
Posted: Sun Oct 14, 2018 10:09 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Jehu Garcia has done an electric samba bus: https://www.youtube.com/channel/UCcMfCkN1juSa49DJFYltOTw
Electric Vehicle World Tour has used tesla batteries with a Renault? electric motor on a vanagon: https://www.youtube.com/channel/UCHOCdckFdBEmTfR1qoW4Atg
There may be an issue getting a prius motor to fit in a vanagon. I'm not sure about the dimensions. There are alot of factors to consider, cost, how to make it fit, making it work, weight, range, power _________________ 83.5 Vanagon 1.9L Automatic
Country Homes Camper
Engel Fridge w/Solar
llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Sun Oct 14, 2018 10:15 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Good question. How hard could it be?
My van has a tiico conversion with less than 30,000 miles so it might be a long time before I need a new engine (I'm of the "if it aint broke don't fix it" mind set). But I foresee a lot of long road trips when I retire and my mpg is 16 city 19-20 highway.
I also see new Audis with 2.0Ts and think in ten years when my engine is toast maybe those will be a good swap.
ps- Prius engine looks tall
_________________ 87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present) |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Sun Oct 14, 2018 11:56 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
pinetreeporsche wrote: |
I dream of a day when my Westie gets 32 or 34 mpg-- or better |
Geared correctly and set up with an eye on aerodynamics 32-34 is already reality for TDI powered westies. With big tires, lift kits, and lots of stuff bolted to the outside of the van they still get ~27. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Sun Oct 14, 2018 12:46 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
The Prius relies on super low drag aerodynamics, and the van is a freaking breadbox. Renerative braking would need to be ported and there is no way a Prius engine would mate with a van transaxle, nor would the Prius transmission handle the weight of a loaded van (if it could even be somehow mated to van axles). Round peg, square hole. TDI is probably the move if MPG is your thing. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Sun Oct 14, 2018 4:55 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
djkeev wrote: |
I have a prius, no way can I see that amount of available power effectively moving a Vanagon!
Dave |
lots and lots of battery assist! my 17 year old has the old family car, a Prius V. power is not it's thing. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Sun Oct 14, 2018 4:59 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
x2. I have to give some serious accelerator pedal to climb a hill in the prius with a full house (4 people). Turn on the AC and you might as well be driving the modern VW bug. The power in a 1.8L prius is abysmal.
For the 2016 Toyota Prius, output is 95 hp at 5200 rpm and 142 N·m (105 lb·ft) of torque at 3600 rpm (wiki). _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Sun Oct 14, 2018 5:21 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
AZ Landshaper wrote: |
For the 2016 Toyota Prius, output is 95 hp at 5200 rpm and 142 N·m (105 lb·ft) of torque at 3600 rpm (wiki). |
that's almost 2.1L wbx numbers! how much do the batteries weigh _________________ 1991 Vanagon GL Camper
82westyrabbit Samba Member
Posted: Sun Oct 14, 2018 5:51 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
I was given a Prius to try that with but when I parked it under the van and started measuring it looked like I would have to do frame splicing to make it work. That was going to be more work than I was up for for. So I did some repairs on it and passed it on to another family member. Any thing can be done but there must be a better solution if you are looking for fuel mileage. John |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Sun Oct 14, 2018 5:57 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
djkeev wrote: |
I have a prius, no way can I see that amount of available power effectively moving a Vanagon! |
I have a 914, no way can I see that amount of available power effectively moving a Vanagon! _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
szegedin7 Samba Member
Joined: April 03, 2017 Posts: 117 Location: Southern California
Posted: Tue Oct 16, 2018 5:56 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Prius-Vanagon is the ultimate dream. I've been pining for this for years.
Have both a Prius and a Vanagon in the family; the Prius actually has more horsepower than the van (110 vs what's left of 90) and is within 200lbs of the weight. (I weighed the van at a local dump -- please don't @ me with Westphalia specs). There's a point of view that says the Vanagon doesn't need more power -- y'all need to mellow out on the acceleration. The Prius feels underpowered because it's not light (curb 2900 lbs).
The aerodynamics are not a big factor at less than @45 mph -- the best mileage I ever got on the Prius was driving around Long Island suburban avenues. The Prius actually gets only slightly better highway mileage than a 2004 Corolla with automatic trans (@40).
A hybrid vanagon would probably come out a little lower than a Prius, but could make up for it with big plug-in batteries. That would be the Business. However, an electric only kind of defeats the purpose of a vanagon -- the long trips.
If VW just started selling the 1990 chassis with a four-cylinder hybrid drivetrain and air bags I would slap down my deposit tonight, but it doesn't add up for them financially.
The other great thing about hybrids is that when you drive them nicely, they aren't working too hard, and have great longevity. So you drive light around town, you can rack up many miles on that thing. Drive them like they're "underpowered" and it's just sort of an average Toyota. People with lead feet are why gas consumption (and co2 emmissions) are not going down while fuel economy improves, but I digress.. |
RCWesty Samba Member
Posted: Tue Oct 16, 2018 6:13 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
With the right motivation and skills anything is possible. I too have a westy and a prius (interesting similarities on thesamba) , but with other higher powered electric motors potentially available, it will be a matter of time before someone makes them plug and play. I saw this Honda a few weeks ago in South Reno take off like a bolt of lightning at a stop light. At first, I thought, man.. What the heck is that? Then, it tore off like a bat outa hell with near absolute silence. Perhaps when more teslas are discovered at pick n pulls, there will be innovations.
https://jalopnik.com/this-glorious-madman-stuffed-a-p85-tesla-drivetrain-int-1823461909 _________________ 89 Burgundy Westy (sold)
90 Blue Syncro Westy |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Wed Oct 17, 2018 8:44 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
The idea of adding electric is great, and I want to do that too. BUT, the reality is that in a similar fashion to Star-Trek and Star-Wars, one is science fiction, and one is science fantasy.
We are at a point where having both gas power AND electric in one vehicle is actually worse for the atmosphere. Its a good idea to move forward, towards cleaner power, but doing both at the same time is only barely okay as a mid-point measure. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed Oct 17, 2018 10:49 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
szegedin7 wrote: |
a Vanagon would never pass current DOT safety standards. _________________ 1991 Vanagon GL Camper
Zeitgeist 13 Samba Member
Posted: Wed Oct 17, 2018 11:02 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
As someone who's logged thousands of miles in Gen1/2 Prius (when I worked for the state), I can definitively state that it's not a drivetrain I would ever want for a mid-sized van. But it would make much more sense to use a FWD minivan platform than the oddball T3 arrangement. A Sienna is where you want to go with this idea. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Oct 17, 2018 11:28 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Z'g, ya, agree on the T3 platform layout issue. As for a Prius, Um.... well, a tintop base model IS lighter.. but you still have the issues with this being rated as a 1 ton load hauling capacity vehicle. Perhaps the notion has not yet crossed the OPs mind; there are hybrid Highlanders. Them are heavier, not a 1 ton load machine, by any means, but closer.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Wed Oct 17, 2018 11:41 am Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Zeitgeist 13 wrote: |
As someone who's logged thousands of miles in Gen1/2 Prius (when I worked for the state), I can definitively state that it's not a drivetrain I would ever want for a mid-sized van. But it would make much more sense to use a FWD minivan platform than the oddball T3 arrangement. A Sienna is where you want to go with this idea. |
A Pilot, Shirley. You meet the nicest people in a Honda Pilot. _________________ .ssS! |
caravelle c Banned
Joined: November 03, 2014 Posts: 153 Location: Bavaria-Germany
Posted: Wed Oct 17, 2018 3:08 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Comparable size of a Vanagon is a Porsche Cayenne. Porsche didn't put a 95hp 145Nm engine in its Cayenne hybrid. |
handjammer Samba Member
Posted: Wed Oct 17, 2018 5:19 pm Post subject: Re: Has anyone completed a Prius power conversion into a Vanagon? |
Check out the 2019 Crosstrek hybrid. It's the same 152hp 2L boxer but mated with Toyota's Prius Prime. Wouldn't that be a much more viable option? _________________ '87 tintop syncro w/ EJ22 |
