chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Sun Oct 14, 2018 9:46 am Post subject: Where is this water coming from? Rust on rear cross members. |
It seems like the rust on my rear crossmembers gets wet when it rains, even though I haven't driven.
I have rust in the same spots on both sides. I cleaned and prepped the areas for rust bullet friday night and let dry over night. It rained over night and the areas are soaked in the morning.
It seems like this is a very common rust area in these cars. I know people say these things get beat up with rocks snow and salt, but I'm not buying that when the car hasn't moved
So, it leads me to believe that there is water coming from some and draining into/onto the rear cross members.
What are the likely places?
I tried spraying water on the back window and side window. The side window dripped down the fender and into the hole on the right.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Oct 14, 2018 1:40 pm Post subject: Re: Where is this water coming from? Rust on rear cross members. |
Leaking at your warped moonroof and running downhill in the roof? Tear out your headliner/interior so you can See what is happening. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Oct 14, 2018 1:44 pm Post subject: Re: Where is this water coming from? Rust on rear cross members. |
Mike Fisher wrote: |
Leaking at your warped moonroof and running downhill in the roof? Tear out your headliner/interior so you can See what is happening. |
Good memory.
there is no headliner and I was able to get the moonroof leaking down to 1 or two drops per rainstorm.
Someone suggested it might be the rear exterior vent below the rear windshield, I poured a bunch of water in there and it only soaked my motor, but didn't come out of the crossmembers. What a bad design!!! |
VintageVulture Samba Member
Joined: May 25, 2003 Posts: 789 Location: Pacific Northwest- USA
Posted: Sat Oct 27, 2018 12:06 pm Post subject: Re: Where is this water coming from? Rust on rear cross members. |
Its coming from the years of wet roads and condensation seeping into the poorly rust inhibited panels that VW produced. _________________ The best things in life aren't Things
(they're Buses) |
beetlenut Samba Member
Posted: Sat Oct 27, 2018 5:53 pm Post subject: Re: Where is this water coming from? Rust on rear cross members. |
Since all the grit and sand from the rear wheel is constantly blasting that area as it comes off the rotating wheel, coupled with the fact that the cracked undercoating is always holding moisture against the metal in that area, it really never stood a chance! I've replaced both those areas, and also the rear of the front wheel-wells that also have the same thing going on. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sun Oct 28, 2018 6:18 am Post subject: Re: Where is this water coming from? Rust on rear cross members. |
beetlenut wrote: |
Since all the grit and sand from the rear wheel is constantly blasting that area as it comes off the rotating wheel, coupled with the fact that the cracked undercoating is always holding moisture against the metal in that area, it really never stood a chance! I've replaced both those areas, and also the rear of the front wheel-wells that also have the same thing going on. |
What I have come to realize is that this could be 20 years old and its really not that bad for a northeast car.
The area is still basically solid, so I'm going to do a through rust treatment and coat with rust bullet.
If it doesn't show any activity in the next 6 months I'll cover it with some glass. |
oldmanmark Samba Member
Joined: July 08, 2006 Posts: 842 Location: n.w. indiana,chicagoland
Posted: Mon Nov 12, 2018 5:14 pm Post subject: Re: Where is this water coming from? Rust on rear cross members. |
You live in New Jersey. Winter, summer, hot, cold rain, snow, salt, condensation, age. Plus the rear wheel are thowing rocks at it. _________________ its all up to you and me to make it better... |
Posted: Tue Nov 13, 2018 12:13 pm Post subject: Re: Where is this water coming from? Rust on rear cross members. |
Actually, now that sealed up the rusted out ends of the panels that terminate just in front of the rear wheel there is significant less water in the car. Just a few drips from the moon roof. |
