malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sun Oct 14, 2018 10:51 am Post subject: vent lever removal |
I found a few posts on the subject.... Best so far is https://www.thesamba.com/vw/forum/viewtopic.php?p=4598181
But it does not answer my question. I was going to reply, but figured I should just start a fresh one.
The bentley mentions the PINS holding the levers in and that they have to be removed to remove the dash panel. But no word on HOW. Shall I just cut them? Are there replacements? You can kinda see in the picture that I have been working the end of the closest one to you, but just don't have the right tool to push 4 tabs and then push them all out. PITA.
Once out, I might even consider not replacing them. My MK1 vw levers are plastic and just slide in and out. fingers are crossed. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Oct 14, 2018 11:18 am Post subject: Re: vent lever removal |
The white 4-tab pins are difficult at first, but get easier with experience. By #4 you’ll be a pro. Use a small socket (like 6mm +/- 1mm) to push the four tabs closed and push the white pin out at the same time.
Generally speaking, I don’t reinstall them on my own bus. The metal tabs exert enough pressure on the control knobs to function well unless your passenger is an ape who doesn’t understand basic directions.
www.airschooled.com
vwmerckx Samba Member
Joined: August 12, 2012 Posts: 195 Location: Phoenix, AZ
Posted: Sun Oct 14, 2018 11:51 am Post subject: Re: vent lever removal |
Agree with Robbie....the pins really are not necessary and the leaf-type spring pressure holds the levers in well enough. On my 71 Tintop, two pins crumbled and I cut the other two out with wire cutters. I did purchase replacement pins ($2.40/pair) and levers from EIS: https://www.eisparts.com/product-search.html?Search=air+levers
but never installed the pins |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Sun Oct 14, 2018 12:05 pm Post subject: Re: vent lever removal |
I made a tool out of a butter knife it pops them right out one of these threads shows it. as with Rob I don't reinstall them. _________________ where its cold and snowy |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Oct 14, 2018 12:42 pm Post subject: Re: vent lever removal |
I use a socket, never a problem. I save them for mounting emblems since they are the same part. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Oct 14, 2018 12:56 pm Post subject: Re: vent lever removal |
busdaddy wrote: |
mounting emblems since they are the same part. |
HA I did not know that lucky I have been saving them (the hoarder in me) _________________ where its cold and snowy |
Posted: Sun Oct 14, 2018 5:30 pm Post subject: Re: vent lever removal |
nothing I tried worked for me. Hell, I even had trouble cutting them off. But they are now off. I may have saved 2, but they are ugly.
Thanks for chiming in. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
