malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sun Oct 14, 2018 4:52 pm Post subject: dash display bulbs ???? |
While waiting on my RUST CONVERTER to convert, I started pulling the dash.
I decided to destroy the little pins that hold the vent controls. Seems like what most folks do.
Then I got the gauges out and started checking bulbs. The 914 BBS guys have taught me that the G light must remain incandescent. On the 914 the bulb actually helps start the charging process. LED will not pull enough amps, or something like that.
I have a box of LED bulbs to change. I changed the back lighting, the Bright and Parking indicators. But that is it.
Anyone go with all LED? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
babysnakes Samba Member
Posted: Sun Oct 14, 2018 5:10 pm Post subject: Re: dash display bulbs ???? |
I have not, but the general consensus is the G light remains incandescent. LED for the rest. |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Sun Oct 14, 2018 5:35 pm Post subject: Re: dash display bulbs ???? |
I think the real problem with an LED is it won't dim correctly.
I can't find it, but I was just reading a post Telford made saying you can put an resistor in series with the LED to provide the load that the alternator needs. He didn't recommend it per se, but said it could be done.
If you have a T1 motor with an alternator, and only use that light to indicate the presence of the fan belt, then you could go all LED in theory. _________________ ~Kevin
My 1968 Campmobile |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sun Oct 14, 2018 7:29 pm Post subject: Re: dash display bulbs ???? |
Hikelite wrote: |
I was just reading a post Telford made saying you can put an resistor in series with the LED to provide the load that the alternator needs. |
Pretty sure that would be "in parallel" rather than "in series". To provide the current the alternator needs to start charging, not the "load". No doubt the LED lamp already has
a resistor in series, otherwise it would burn up with battery voltage applied to it. _________________ '67 bug: seized by the authorities
Posted: Mon Oct 15, 2018 7:52 am Post subject: Re: dash display bulbs ???? |
Hikelite wrote: |
All 3 of my 914 gauges are back-lit with LED bulbs. I don't have an issue adjusting the brightness. They all work. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Oct 15, 2018 9:43 am Post subject: Re: dash display bulbs ???? |
A resistor paralleled with an LED dash lamp will allow enough current to flow to the alternator to start properly. The stock bulb (N17 751 2) is a 12 volt, 1.2 watt lamp. This means that it has an operating resistance of 120 ohms. I'd use a 100 ohm, 2 watt resistor (Frys, Mouser, Digikey, etc.) paralleled with the LED (a little extra current won't hurt).
Yes, LEDs are dimmable, but you can't do it successfully by adding resistance. You do it by using pulse width modulation (turning the LED on and off electronically really fast such that you can't see the flicker). You can buy dimmer controls using this technique on Amazon.
Here's a link to my dash light LED conversion. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Tue Oct 16, 2018 10:21 am Post subject: Re: dash display bulbs ???? |
The other thing the G light does is come on when the battery positive or negative falls off and the alternator or generator is producing a too-high voltage.
For that you need a filament bulb, as the current flows the other way through the bulb to the usual generator/alternator not outputting enough voltage scenario.
The LED would stay off while any electronics in your bus is being fried. _________________ Ancient vehicles and vessels
Posted: Tue Oct 16, 2018 11:14 am Post subject: Re: dash display bulbs ???? |
How long is your Charge Light ever on? A few seconds every time you drive you rig. There aren't any great savings on changing it out and for the vast majority of time the amount and color of the light isn't going to make any difference to the appearance of your dash as the light just isn't on enough to matter. |
