narrowfarm Samba Member
Posted: Mon Oct 15, 2018 2:02 am Post subject: vw stock exhaust system |
Hello I am wondering if my 1300cc single port 1966 engine could take a 1200cc exhaust?? I don't need the heat set up for my convertible summer time kit car. I am looking to possible buy the 1200cc stale air exhaust system. I just have the j tubes on the 1300cc engine and would like to use the heat riser ports on the 1200cc stale air muffler which is much simple design compared to the stock 1300cc exhaust system with all the heating ports that I don't need.
. My 1300cc has an after market exhaust system and my intake manifold builds up condensation and gets cold. The after market heat risers are not working properly
Will the 1200cc exhaust bolt up to the 1300cc engine??? I just need the simple design and the heat riser tubes as the 1200cc has. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Mon Oct 15, 2018 5:05 am Post subject: Re: vw stock exhaust system |
No. The 1200 engine is narrower between the exhaust flanges.
And even between 1200, the reach of the different style mufflers is different. Also the diameter of the sealing ring - stale air has a 32mm ID and fresh air has the same 35mm of the tailpipe. Here's a photo of a 1200 fresh air muffler on a 1200 stale air engine - you can see they don't line up:
_________________ Andy T.
Denny B Samba Member
Posted: Mon Oct 15, 2018 7:39 am Post subject: Re: vw stock exhaust system |
This gets my curiosity up....I have a '65 Beetle that I thought was a 1200 but I have the muffler in the top photo (1300-1600). So...is my '65 Beetle a 1300? |
Posted: Mon Oct 15, 2018 7:45 am Post subject: Re: vw stock exhaust system |
Are you sure it's that top muffler? There have been several different manufacturers over the years.
What's the engine serial number? (that will only give you born-as info, and all kinds of changes can happen in half a century, but it's better than nothing)
Fresh air was introduced on the 1200 in mid December 1962. Those have the extra ducts leading down to the heater boxes and they look similar to the 1300-and-up heater boxes but they are still narrower. The last couple comparison images above are between stale and fresh air 1200 mufflers.
Okay, let's fall back on the cylinder head and intake manifold ID image:
mukluk Samba Member
Posted: Mon Oct 15, 2018 8:20 am Post subject: Re: vw stock exhaust system |
narrowfarm wrote: |
You do realise you can just uncrimp or cut and remove the two fresh air manifolds from the typical stock 1300-1600 muffler, right? They're just sheet metal; might take you about fifteen minutes to remove them, tops. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Oct 15, 2018 2:52 pm Post subject: Re: vw stock exhaust system |
Thanks so much for the pictures!! just curious what dose the fresh air ports do?? |
Posted: Mon Oct 15, 2018 3:17 pm Post subject: Re: vw stock exhaust system |
Well, they are part of the heat exchanger system. The heater boxes themselves transfer heat from cylinders 1 and 3, but the shells on the muffler do something of the same for cylinders 2 and 4 - the fan shroud blows air over those hot pipes before going through the heater boxes, maximizing the heat delivered to the car.
Oh, and yes they can be removed. I've taken them off before - sometimes they are the only good bits remaining on rotted out German mufflers, and prying them off in such a way that they can be re-used, well it's a bit of work, but those old German ones are sometimes a bit better than the ones found in the aftermarket, and changing them out can be a good thing. Also I went kind of the opposite way - I don't mind the additional heating effect of these so I flipped a left side shell upside down and made it fit onto the right side of the Offroad Extractor on my Baja Bug. (I was never able to make it work for the left side though)
Posted: Mon Oct 15, 2018 3:56 pm Post subject: Re: vw stock exhaust system |
glutamodo wrote: |
My engine # is: 9629625
My intake manifold looks like the photo to the left so I guess I have a 40HP 1200cc. |
