malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Mon Oct 15, 2018 7:08 am Post subject: Turn signal indicators. Are they rgt & lft |
OK, probably a stupid question and I will find out the answer one day. I have never driven a bus. Had a couple bugs in the 80's and currently have a 75 915.
The bugs and the 75 914 have a single turn signal indicator. I back dated my 914 gauge to a silver dot from a 72 914 and they have individual blinker lights. I like the look of the silver dot, plus the 75 mph gauge was 150 and the silver dot is 120. Never gonna drive that fast....
I had to rewire the blinkers thru the hazard switch to work separately. I need to find my drawing on that.
I took out the gauges of my 72 bus this weekend and noticed that it has separate rgt & lft indicators but there is a single Blue/Red wire feeding both bulbs.
So can the blinker stalk make them work individually? Not an electrician but know enough to be dangerous (and ask stupid questions).
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Mon Oct 15, 2018 8:07 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
No.
Both indicator bulbs blink together. They are for all purposes the same as the single indicator bulb in a Beetle but for some reason VW decided to use two bulbs in a Bus. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
SGKent Samba Member
Posted: Mon Oct 15, 2018 9:01 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
It is my understanding that VW went with a right and a left bulb when they designed the dash but never upgraded the wiring to match. It would be easy enough to do I would think, just tie into the wiring for the front turn signal bulbs. |
Posted: Mon Oct 15, 2018 9:10 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
It would be doable but a little more involved than just connecting to the front turn signal wiring.
The turn signal indicator is kind of a weird reverse-polarity thing. The indicator bulbs are powered all the time the ignition is on via the same internal bus that powers the other warning light bulbs.
They get ground from the flasher relay intermittently as the turn signals flash, so they flash opposite from the external bulbs. When the external bulbs are lit, the indicator is off and vice versa.
If you just removed the wires to the indicator bulbs and connected them up to the front turn signal bulb, you'd basically have 12v to both sides of the bulbs (1 steady 12v source and one intermittent source) and no ground path - so the indicator bulbs either may not flash at all or may try to ground through the other warning lights making your oil/gen lights flash and your fuel gauge swing around. Could be interesting. _________________ 1965 Volkswagen 1500 Variant S
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2537 Location: Ocean Beach in Beautiful BLUE California
Posted: Mon Oct 15, 2018 9:13 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
Someone on here a long time ago published a schematic on building a small black box to get separate lights. Could not find it on a quick search. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Mon Oct 15, 2018 9:15 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
Wildthings wrote: |
I have a drawing somewhere that I used to set up my 75 914. Once I find it I will post it here. It was not difficult to figure out, but there are quite a few wires, and IIRC you have to make a mini-harness. I'll find it. I know it is on 914world.com, but my search is not pulling it up. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Mon Oct 15, 2018 10:26 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
sjbartnik wrote: |
If you just eliminate the wires to the indicator bulbs and connected them up to the front turn signal bulb, you'd basically have 12v to both sides of the bulbs (1 steady 12v source and one intermittent source) and no ground path - so the indicator bulbs either may not flash at all or may try to ground through the other warning lights making your oil/gen lights flash and your fuel gauge swing around. Could be interesting. |
Separate the ground side of the turn indicator lights from the emergency circuit and tie them into the wires supplying the turn signal bulbs, done. They will flash alternately to the bulbs. Maybe there is something I don't under stand about this circuit, but it seems simple enough. I really doubt that the minor current draw of the indicator bulbs is important to the operation of the emergency flasher as the circuit alternately has power or a low impedance ground through the filaments of the four turn signal bulbs. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Mon Oct 15, 2018 10:30 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
The easiest way to blink the indicators individually is to use (small) 12 volt relays. Wire one end of a relay coil to each front turn lamp. Ground the other end of each coil. Use the relay contacts to ground the terminal on the dash indicator.
(You can use small mosfet transistors in place of the relays, but that would involve circuit fabrication.) _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Mon Oct 15, 2018 10:57 am Post subject: Re: Turn signal indicators. Are they rgt & lft |
Found my pix... and the 914world post. http://www.914world.com/bbs2/index.php?showtopic=248604&hl=silver
As mentioned above, I had to get a bulb holder with 2 connections and loop the ground together. Then I used the correct wire from the hazard switch and ran it to the correct bulb. Used some "fancy" connectors and it worked.
I guess I will tinker with the bus set-up and see if it is similar enough for me to figure out.
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Mon Oct 15, 2018 1:22 pm Post subject: Re: Turn signal indicators. Are they rgt & lft |
malcolm2 wrote: |
I had to get a bulb holder with 2 connections and loop the ground together. |
That's exactly what I did with my bus turn signal wiring circa year 2000. Just connected to the black/white and black/green
wires coming from the t/s switch, and a ground to each indicator bulb. Back then, bus instrument bulb holders with two connectors were
available from several sources. In recent years, I haven't been able to find them anywhere. _________________ '67 bug: seized by the authorities
