Seat belt hook round knob replacement?
dstimm
dstimm is offline
PostPosted: Mon Oct 15, 2018 7:22 am    Post subject: Seat belt hook round knob replacement? Reply with quote
Does anyone know where to find replacement knobs that hold the seat belt hook in place? Mine are crumbling and brittle.
Thanks!
1979 Sage Green California Westy.
Angus II
Angus II is offline
PostPosted: Mon Oct 15, 2018 8:18 am    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
Hello,
The Bus Depot has them. Or check the classifieds.
CanStan
CanStan is offline
PostPosted: Mon Oct 15, 2018 8:28 am    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
I think all the usual vendors sell them. I got some from CIP. The belt hooks and coat hanger knobs are separate parts, but should be well under $20 for all 4 pieces if you're replacing both driver and passenger sides.
CanStan
CanStan is offline
PostPosted: Mon Oct 15, 2018 8:31 am    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
Here you go:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16-255-8639-WH
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16-211-723
sodbuster
sodbuster is offline
PostPosted: Tue Oct 16, 2018 12:57 pm    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
West coast metric has them, plus they are closer to where you are.
http://www.westcoastmetric.com/i-22968289-211-723.html
http://www.westcoastmetric.com/i-22967208-255-8639-wh.html
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Wed Oct 17, 2018 5:45 am    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
Buy a handful of them. Passengers will break those off when they grab the belt to buckle it without un-hooking it first.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
udidwht
udidwht is offline
PostPosted: Thu Oct 18, 2018 7:24 pm    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
Indeed they will. Bewilders me that people can't figure out that they hang on a hook. LOL!
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
Boesen
Boesen is offline
PostPosted: Fri Oct 19, 2018 2:12 am    Post subject: Re: Seat belt hook round knob replacement? Reply with quote
https://uniwerksdesign.com/product/westfalia-coat-hook-set/
1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa
