JaxWaxMan Samba Member
Posted: Mon Oct 15, 2018 7:49 am Post subject: engine in another model year |
Guys,
I have a '72 beetle and my engine just died. I'm in the midst of rebuilding a 40 horse from my '62 that's in the shop for bodywork. Can I put the completed '62 40 horse engine in the '72 without too much trouble, so I can drive it until I get to the '72 dual port?
thanks, |
mini t Samba Member
Posted: Mon Oct 15, 2018 8:01 am Post subject: Re: engine in another model year |
yes it should bolt right up maybe a little less hp then your other motor |
Zundfolge1432 Samba Member
Posted: Mon Oct 15, 2018 8:17 am Post subject: Re: engine in another model year |
Is the 40 hp still 6v ? You could use a 6v 200mm flywheel to use later diaphragm pressure plate because 62 pressure plate will not work with later throw out bearing. Also starter will be a problem |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Mon Oct 15, 2018 8:38 am Post subject: Re: engine in another model year |
Just one problem, you can't put an O-ring flywheel onto a step crankshaft... _________________ Andy T.
Posted: Mon Oct 15, 2018 8:39 am Post subject: Re: engine in another model year |
6v 200mm comes both ways and actually the o ring was 1 year only item 1966
Last edited by Zundfolge1432 on Mon Oct 15, 2018 8:47 am; edited 1 time in total |
mukluk Samba Member
Posted: Mon Oct 15, 2018 8:45 am Post subject: Re: engine in another model year |
glutamodo wrote: |
Just one problem, you can't put an O-ring flywheel onto a step crankshaft... |
Type 2 & 3 flywheels up through '65 are 200mm, 109 tooth count, and no o-ring. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Oct 15, 2018 8:50 am Post subject: Re: engine in another model year |
Yes, but how likely are you be having one of those. The bog standard flywheel likely to be found in a 72 Beetle will not fit the USA 40HP crank unless you machine it. I'm just warning that you can't just easily shift everything over. _________________ Andy T.
mukluk Samba Member
Posted: Mon Oct 15, 2018 9:03 am Post subject: Re: engine in another model year |
You are right and then there’s the starter. You could use the 6 volt to match the 6 volt 200mm flywheel but I’d turn down the shaft to smaller 12v size rather than use Mickey Mouse thin conversion bushing. A real challenge to beginners but it’s doable. Concerning availability of 6v 200mm flywheel I found one at swap this year for 5 bucks, nobody knew what it was. |
mukluk Samba Member
Posted: Mon Oct 15, 2018 9:10 am Post subject: Re: engine in another model year |
Question: since it appears some folks have had good luck removing the center ring on early diaphragm style 200mm pressure plates, converting them in essence to late style, do you think it would be possible to do the same with a diaphragm style 180mm pressure plate? This would help avoid having to swap out flywheels and reset endplay. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Oct 15, 2018 9:11 am Post subject: Re: engine in another model year |
Yeah, but why buy a niche product for just a temporary use. I guess its rarity might have re-sale value later on though.
Going away from the flywheel stuff, I will relate the time when I pulled the 1600DP engine out of my Baja Bug for repairs and temporarily placed into it a spare big-bore 40HP (1385) engine - the whole engine setup with the 180mm flywheel/clutch and I swapped starters to make it work. The car drove OK but man, it was annoyingly gutless compared to my normal engine.
Edit: I just noticed the latest question. Yes some people have removed the contact plate on 180 diaphragm clutches to make them work with the later setup. _________________ Andy T.
Posted: Wed Oct 17, 2018 10:05 am Post subject: Re: engine in another model year |
Thanks for all the replies. I guess when I get the 40 HP rebuilt, I'll see what happens. |
