StevieSteve Samba Member
Joined: January 05, 2017 Posts: 15 Location: Jacksonville, Fl
Posted: Mon Oct 15, 2018 1:53 pm Post subject: Vanagon Slider Door Storage Hack |
I am working to fabricate all new interior paneling in my 84. Once I remove the paneling in the slide door it will be trash, its basically being held together by the plugs. Has anyone ever considered making storage inside the slider door? is there enough space to make some skinny shelving using the door framing? I've looked around and haven't seen too much about it. My intention would be to make small shelving within the door and have the paneling be hinged so it could flip up or out to access it. Id love to hear about any ideas, experiences, or absolute failures! Thanks! |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Mon Oct 15, 2018 2:11 pm Post subject: Re: Vanagon Slider Door Storage Hack |
not an amazing amount of space for storage. the door latch pull cuts across the door. that right there limits the available space. don't hack the metal, it keeps you safe in a crash. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon Oct 15, 2018 2:14 pm Post subject: Re: Vanagon Slider Door Storage Hack |
Add to the relative lack of depth to the skin/frame on the door, you'd have a couple inches of room to add outward since the door slips outward when sliding back. That, too, is pretty slim. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Gruppe B Samba Member
Posted: Mon Oct 15, 2018 2:15 pm Post subject: Re: Vanagon Slider Door Storage Hack |
Vanagon book storage!
(photo is flipped, not a double slider ) |
the joker Samba Member
Posted: Mon Oct 15, 2018 2:19 pm Post subject: Re: Vanagon Slider Door Storage Hack |
in my rear hatch, I stow a spare set of engine coolant hoses, just put the panel back, and know it's there
the slider works to much to kept stuff there to access , one good slam, stuff would be falling out, just my thoughts. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Oct 15, 2018 2:41 pm Post subject: Re: Vanagon Slider Door Storage Hack |
I just take less stuff. |
danfromsyr Samba Member
Posted: Mon Oct 15, 2018 5:45 pm Post subject: Re: Vanagon Slider Door Storage Hack |
while I plan to use some of that space for the sandals/flip flops..
the middle of my door panel touches the side of my van on occasion.
so you really can't get any thicker. _________________
Abscate wrote: |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Mon Oct 15, 2018 6:39 pm Post subject: Re: Vanagon Slider Door Storage Hack |
Doesn't somebody make an extension kit for the slider ? |
DuncanS Samba Member
Posted: Mon Oct 15, 2018 8:07 pm Post subject: Re: Vanagon Slider Door Storage Hack |
Here's what I did on the rear hatch. The same could be done on the slider as well. The rear catch releasee could be done through a Bowden cable and routed to where you want it to go so it does not need to go through the middle of any available space. One of the beauties of door storage--or hatches--is that no matter how the van is loaded, there is nothing in the way when you open the door. Of course in the case of the slider, you have to be inside to access at least the back part of any storage, but you could reach around the front half and get to tire irons, jumper cables and the like.
Those are jumper cables in a bag on the left. |
scottz Samba Member
Joined: April 13, 2008 Posts: 477 Location: Bellingham, WA
Posted: Mon Oct 15, 2018 8:41 pm Post subject: Re: Vanagon Slider Door Storage Hack |
DuncanS wrote: |
I love this idea with the hinge! That's great!
Adding a pocket to the slider seems useful when the slider is closed but, if someone puts something too large in the pocket and you open it from the outside or just forget, you could easily scratch the van or worse. Besides, my slider door card is a work of art. I'm moving on to the rear hatch panel.
I believe the grey one above is from sewfine. |
Posted: Sat Oct 20, 2018 7:28 am Post subject: Re: Vanagon Slider Door Storage Hack |
thanks for the tips! I am going to look into options with the back hatch. I didn't even think of that. appreciate it everyone! |
jimf909 Samba Member
Posted: Sat Oct 20, 2018 7:35 am Post subject: Re: Vanagon Slider Door Storage Hack |
DuncanS wrote: |
Neato. That's one more creative solution from DuncanS. Thanks for sharing this. Every (Vanagon) body cavity can become a storage space. _________________ - Jim
Abscate wrote: |
