1987 Vanagon Mystery electronics
aeromech
aeromech is offline
PostPosted: Mon Oct 15, 2018 2:10 pm    Post subject: 1987 Vanagon Mystery electronics Reply with quote
Guys,
Can anyone tell me what this mystery gizmo is? It has a red LED on it.
Thanks
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
the joker
the joker is offline
PostPosted: Mon Oct 15, 2018 2:25 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
more info, what's it hooked to hoses Question
aeromech
aeromech is offline
PostPosted: Mon Oct 15, 2018 2:26 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
I don't know yet. The owner was Tom Powell and he's dead now.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
DanHoug
DanHoug is offline
PostPosted: Mon Oct 15, 2018 2:32 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
if that vacuum hose is attached to the box, he's made a vacuum actuated throttle switch with LED indication! that vacuum line is T'd off of the port that should have less than 1" at idle and increases when the throttle is opened. the purple line controls the purge valve on the charcoal canister.
-dan
www.thefixitworkshop.com
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Oct 15, 2018 2:33 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
Looks like one of the vacuum switch replacements for the throttle position switch that originally was part of the throttle body assembly.
Mark
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Oct 15, 2018 2:34 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
Isn't that one of Vanistan's old vacuum actuated TPS?
Casey--
'01 Weekender --> full camper
y u rune klassik?
Steve Arndt
Steve Arndt is offline
PostPosted: Mon Oct 15, 2018 2:56 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
That is the tencent / Rocky Jennings VSM vacuum switching module. I liked mine. It recently died. The electronics and case are not made for a HOT/COLD engine compartment environment. There was a lot of corrosion inside mine when I took it apart to inspect after it quit working.
Steve
Steve's 87 Syncro project
dabaron
dabaron is offline
PostPosted: Mon Oct 15, 2018 4:17 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
i believe i found the workshop manual for it Laughing
1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC
aeromech
aeromech is offline
PostPosted: Mon Oct 15, 2018 8:03 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
Thanks dabaron,
Whatever that means is a big help buddy.
So the Led light comes on when I blip the throttle off idle. The wires hook into a harness connector near the AFM and there is a vacuum hose to a Tee near the intake. Any idea what this thing does?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
dobryan
dobryan is offline
PostPosted: Tue Oct 16, 2018 4:44 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?p=5901510
Dave O
The Western Syncro build
tencentlife
tencentlife is offline
PostPosted: Tue Oct 16, 2018 8:26 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
Vanistan VSM. It was my product.
The design specs anticipated the temps that would be encountered in North America, cold being the more critical factor. A Vanagon engine compartment doesn't reach 160ºF, that's barely warm to electronics. It's normally under 135ºF where the VSM rides.
What it wasn't was potted, so it is susceptible to water and pollutants. Where it's mounted in the engine bay it's not exposed to much of either. You're the only one to ever mention any damage.
Shop for unique Vanagon accessories at the Vanistan shop:
Experience is kryptonite to doctrine.
Steve Arndt
PostPosted: Tue Oct 16, 2018 8:48 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
Is there a Warranty or support? I wouldn't mind trying to bring it back to life.
Steve
DanHoug
DanHoug is offline
PostPosted: Tue Oct 16, 2018 9:04 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
the Support is to remove the 4 screws holding the lid on and show us a clear picture of the inside! we'll tell ya what is wrong with it and how to fix it!
-dan
tencentlife
PostPosted: Tue Oct 16, 2018 10:07 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
My stuff all comes with full warranty and support for one year. You bought yours over 9 years ago. I haven't even sold these in over 4 years.
I had one known failure of the 5V VR chip, that's easy to test with a VOM, or if the chip is very hot it's failed, soldering in a new one will probably fix it. Get the p/n off the chip. The other reported problems were almost all due to the vac tube loosening on the MAP sensor nipple, open the cover and check that. That's about all I can tell you. Like Dan says, it's often easy to see a failed component by just looking inside.
dabaron
dabaron is offline
PostPosted: Tue Oct 16, 2018 11:30 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
aeromech wrote:
Thanks dabaron,
the question was answered, my first thought was it was "the internet" thus my post AFTER the real answer was posted.
BiWerks Design, LLC
aeromech
aeromech is offline
PostPosted: Tue Oct 16, 2018 11:51 am    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
We have enough smart asses here
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
dobryan
dobryan is offline
PostPosted: Tue Oct 16, 2018 12:00 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
Laughing Very Happy Very Happy Laughing
Dave O
Zeitgeist 13
PostPosted: Tue Oct 16, 2018 12:14 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
I suspect there are a few dumb asses pretending to be smart asses. A wise ass knows how to differentiate between the two.
Casey--
y u rune klassik?
dabaron
dabaron is offline
PostPosted: Tue Oct 16, 2018 12:38 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
i'll be the dumb ass then.
BiWerks Design, LLC
joetiger Premium Member
joetiger is offline
PostPosted: Tue Oct 16, 2018 12:42 pm    Post subject: Re: 1987 Vanagon Mystery electronics Reply with quote
I'm already playing that part, but I suppose there's room for more. Very Happy
Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
