Preserving cover from a middle seat when removing
azbob
azbob is offline
PostPosted: Mon Oct 15, 2018 7:43 pm    Post subject: Preserving cover from a middle seat when removing Reply with quote
Long story short, I got a bad 2/3 backrest cover for a 67 only and didn't realize it until I was 1/2 way through installing. Front installed correctly, back did not line up, at all. So I need to figure out how to remove the plastic strip from the slot in the seat frame. Its a pretty tight fit and I know there has to be a trick to do this, I'm just not finding one through the ol google machine.
Any one know of tricks to get those plastic strips out of that slot?
Bus Builder
NAES
NAES is offline
PostPosted: Tue Oct 16, 2018 6:35 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
I would need some pics to understand what you're talking about.
Barndoor Mafia
Box On Wheels
SBS #00
Z
Z is offline
PostPosted: Tue Oct 16, 2018 7:23 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
I think you could open up the slot gently with a screwdriver, etc., enough to release the anchoring strip from the channel. Even if you have to touch up the seat frame, it should be ok, assuming that your seat frame/channel are in good enough shape to stand some gentle bending.
azbob
azbob is offline
PostPosted: Wed Oct 17, 2018 11:02 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Here's what I had to send TMI to explain what the problem was. Should show that the front of the seat cover has the plastic installed.
To be honest, I think they still don't understand what the problem is. Confused
Z - I'm not certain I'd want to pry it apart. I guess that may be the option tho. I'm thinking there has to be an industry trick to getting it out w/o damaging the frame, right? ¯\_(ツ)_/¯
Bus Builder
campingbox Premium Member
campingbox is offline
PostPosted: Wed Oct 17, 2018 5:50 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Oops. Looks like they made a mistake.
I’ve taken them apart when I’ve had one side in like that with a pick. It’s a challenge. Relieve some pressure with your hand, then start at one side and work it out with a pick and a putty knife.
It might be easier and cleaner just to leave it in, cut that plastic strip with some dykes, but be careful not to cut the thread, then tie the thread off and move on.
azbob
azbob is offline
PostPosted: Thu Oct 18, 2018 4:20 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
I'll give it a try tomorrow. I'd rather not have to cut the thing but if I gotta then I gotta. Seems like a waste to do that though. Thanks!
Bus Builder
Douglas Denlinger
Douglas Denlinger is offline
PostPosted: Thu Oct 18, 2018 7:41 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Bob,
I can fix the problem.....is TMI sending you a replacement?
If not it will take me about an hour.
Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986
azbob
azbob is offline
PostPosted: Thu Oct 18, 2018 9:16 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
@Doug - I got the replacement the other day, just looking ideas on how best to remove the defective one w/o cutting it. I think I'll be using a couple O ring picks and hooks.
Bus Builder
zozo
zozo is offline
PostPosted: Fri Oct 19, 2018 7:53 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
The back on mine was about 2" too long. I'd have had to put a 6" mattress inside to take up the slack. WW wasn't even slightly interested in doing anything about it. C'est la vie.
hitest
hitest is offline
PostPosted: Fri Oct 19, 2018 8:24 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
You'll need to make a way to support your seat firmly to something and inch by inch, work the cover off while compressing the spring pack. Just like install but in reverse for folks who don't use the "inside out" method of install. Get your work space warm. Keep the material soft. Squeeze each side bolster with one hand and work the material up with the other. Pull up an inch this side, an inch that side, and so on. It will take exactly 35 minutes and you will have the gripping strength of a bulldog when you're done.
Incidentally, I had the same issue using a '63 short middle seat in a '66. The center support apparently is located differently from year to year. Doug D is right- the center can be "relocated" with a new cut and sewing up the remaining strip. Anyone who can see Doug's repair is too damn close to your bus! Cool
FU#5
azbob
azbob is offline
PostPosted: Fri Oct 19, 2018 9:08 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Yeah, absolutely no interest what so ever. One liner responses, no context to the questions they were asking. Wanted a pic of the handle on the middle seat with no explanation why... Ended up having to call TMI to get it handled. Even that required me drawing it out for them... It was almost like it was my fault I ordered a defective seat cover.
Bus Builder
azbob
azbob is offline
PostPosted: Tue Oct 23, 2018 9:04 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Ended up having to cut the strip. I tried...
Here's how lovely the replacement fits Rolling Eyes
Bus Builder
zozo
zozo is offline
PostPosted: Tue Oct 23, 2018 9:16 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
That looks a whole lot better than mine. Other than the pucker in the center, it looks like it fits fairly well. Also, once it's in the bus, you have to be something of a contortionist to even see that.
I'd like to see more pictures if you get a chance, highlighting the more challenging areas as well as the overall profile. No worries, if it's a PITA.
azbob
azbob is offline
PostPosted: Tue Oct 23, 2018 9:33 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Agree. I had to pull pretty hard to get that strip to line up with the slot. They sewed it to far to the right. Maybe only about 3/4 of an inch but enough to cause a pucker.
I'll take some pics and post this afternoon. The top corner pleats are not symmetrical. Driver's side is loose, folded and sewed (what I feel) incorrectly. I still have to install the grab bar and maybe that will hide it. We'll see.
Bus Builder
zozo
zozo is offline
PostPosted: Tue Oct 23, 2018 9:37 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
Does anyone have any idea if WW will sell just the backrest cover?
azbob, you've caused me to think about mine being such a mess, and now I want to fix it. Not sure whether to curse you or bless you. LOL
azbob
azbob is offline
PostPosted: Tue Oct 23, 2018 4:39 pm    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
I'll go with curse Wink
Here's some pics.
I still need to find the foam arm rest thing. I know I can find a wooden one but then how would I upholster it? Guess I'll figure it out when I get to that point.
Bus Builder
zozo
zozo is offline
PostPosted: Wed Oct 24, 2018 5:50 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
That looks GREAT! I think your grab handles will mount perfectly. Very nice job.
My armrest has little cracks in the vinyl, but I dare not mess with it for fear of making it worse.
Thanks for the pics. They're prodding me into action, albeit with sloth-like enthusiasm.
azbob
azbob is offline
PostPosted: Wed Oct 24, 2018 10:41 am    Post subject: Re: Preserving cover from a middle seat when removing Reply with quote
I'm pretty sure they wont. WW had to have them make me a replacement even though I bought from WW. 2-4 days delivered when ordered from WW and 3 weeks to get it replaced by TMI.
Bus Builder
