jyl Samba Member
Posted: Tue Oct 16, 2018 1:08 am Post subject: What to do with 14" wheels |
I changed to 16" wheels and tires so I have four 14" wheels with worn tires. Are these worth anything, is there anyone in Portland OR who can use them, or should I simply bring them to the tire shop to recycle?
I kept the best one of the 14"s for a spare, until I can get the spare tire carrier to fit a 225/60-16. I believe the 14" tire is about 1" less in radius than the 16" tire. Safe enough for a limited use spare, I think - agree? _________________ 1988 Westy, Bostig v2.0 |
Posted: Tue Oct 16, 2018 3:20 am Post subject: Re: What to do with 14" wheels |
Someone will take them for sure. If no one else speaks up, I will drive in and get them myself. |
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Tue Oct 16, 2018 4:11 am Post subject: Re: What to do with 14" wheels |
jyl wrote: |
I kept the best one of the 14"s for a spare, until I can get the spare tire carrier to fit a 225/60-16. I believe the 14" tire is about 1" less in radius than the 16" tire. Safe enough for a limited use spare, I think - agree? |
I'm doing the same thing on my 2WD Westy but if you have a Syncro don't use a spare with that size difference. _________________ '87 Westy in Wolfram Grey Metallic |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Tue Oct 16, 2018 5:05 am Post subject: Re: What to do with 14" wheels |
I use a 14" wheel to tighten the rear axle nuts. _________________ Brandon
Instagram @joannthevan |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Tue Oct 16, 2018 5:19 am Post subject: Re: What to do with 14" wheels |
Ive got a bunch myself and didnt think of the spare idea. Was pretty sure I needed a 16" but the point you make about them being nearly the same radius hits home. One could probably buy a larger diam tire at a used tire shop (Tucson has 100s of them) and come close to matching the 16s as long as it fits the carrier.
I college we used the extras to make a raft. Tied em all together and attached a piece of plywood. (Que up some Christopher cross ) _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Pinetops Samba Member
Posted: Tue Oct 16, 2018 5:50 am Post subject: Re: What to do with 14" wheels |
Give them or sell them to someone who needs them. They also are good for late bay window and vanagon rescues. _________________ "A rolling bus gathers no rust." |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Tue Oct 16, 2018 6:46 am Post subject: Re: What to do with 14" wheels |
Are you in snow country? You could mount up a set of snow tires for the winter season. Many folks in New England have a spare set of mounted snow tires.
I have 16s on our 2wd camper and carry a 14 inch spare for now. It would be only to get to a place to deal with the flat.
Steel wheels have there place. If I were traveling anywhere off the beaten path, my preference would be steel rims. They can be bent, straightened, heated and welded. Can't same the same for a mag wheel. _________________ ☮️ |
jlrftype7 Samba Member
Posted: Tue Oct 16, 2018 6:48 am Post subject: Re: What to do with 14" wheels |
I offered 6 free stock 14" steelies , even offered to meet someone if they're local... haven't had any takers... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
rag63 Samba Member
Posted: Tue Oct 16, 2018 9:42 am Post subject: Re: What to do with 14" wheels |
JYL,
PM sent. I'm in Portland.
Thanks,
Dave |
YosemiteBound Samba Member
Joined: August 09, 2018 Posts: 327 Location: Los Angeles
Posted: Tue Oct 16, 2018 10:30 am Post subject: Re: What to do with 14" wheels |
This makes me sad. I still run my oem 14s _________________ 1985 Westy Round Headlights "Liam" |
Ollie W Samba Member
Joined: May 20, 2004 Posts: 798 Location: Portland, OR
Posted: Tue Oct 16, 2018 10:48 am Post subject: Re: What to do with 14" wheels |
Hey, I'm on my 14's too. We should start a club. |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Tue Oct 16, 2018 11:11 am Post subject: Re: What to do with 14" wheels |
jyl, I would recommend strapping them to panniers to help train up for your next STP
-your fellow Pelican _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Oct 16, 2018 1:00 pm Post subject: Re: What to do with 14" wheels |
I stacked mine behind the house and eventually got a Vanagon Rescue Squad call from a guy who had two flats in Nebraska and was limping into Denver on improperly rated tires...He was happy to take them! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
jyl Samba Member
Posted: Tue Oct 16, 2018 2:49 pm Post subject: Re: What to do with 14" wheels |
rag63 wrote: |
JYL,
Thanks,
Dave |
PM'd you back, thanks _________________ 1988 Westy, Bostig v2.0 |
jyl Samba Member
Posted: Tue Oct 16, 2018 2:52 pm Post subject: Re: What to do with 14" wheels |
Thanks all.
I am normally the kind of person who holds on to everything because it might be useful someday. But I think I'm turning into a hoarder so my new approach is to let things go to people who can use them. And I just can't think of a use for the 14" steelies. The snow tire idea was good but I had snow tires on them and the van was still horrid in snow (2WD, no LSD, one snow day here in Portland I couldn't even pull away from my curb).
So, happy to have a Sambaite take 'em and looks like that is happening. _________________ 1988 Westy, Bostig v2.0 |
jyl Samba Member
Posted: Tue Oct 16, 2018 2:54 pm Post subject: Re: What to do with 14" wheels |
SyncroButter wrote: |
-your fellow Pelican |
Dude! I didn't know you were a vanagon owner.
Haven't ridden STP for a long time. All my riding nowadays is commuting. I've got some projects that will finish up next spring and then I figure to have my life back and will do more riding!
You doing okay? I'll PM you my email/cell. _________________ 1988 Westy, Bostig v2.0 |
jyl Samba Member
Posted: Tue Oct 16, 2018 5:35 pm Post subject: Re: What to do with 14" wheels |
rag63 wrote: |
JYL,
Thanks,
Dave |
Dave, I'm not sure if my PMs are working? _________________ 1988 Westy, Bostig v2.0 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Oct 16, 2018 8:21 pm Post subject: Re: What to do with 14" wheels |
4 x 14" wheels = 18" jack stands:
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
rag63 Samba Member
Posted: Tue Oct 16, 2018 10:28 pm Post subject: Re: What to do with 14" wheels |
Thank you. I got your PM and will be in touch tomorrow.
Dave |
E1 Samba Member
Joined: January 21, 2013 Posts: 6543 Location: Westfalia, Earth
Posted: Tue Oct 16, 2018 10:47 pm Post subject: Re: What to do with 14" wheels |
E1 Dipstick Alert:
Post deleted for said dipstickness. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
