chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Tue Oct 16, 2018 6:13 am Post subject: Where should the drain holes be in the door? |
I've looked for them and can't find them.
Getting ready to just drill some. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Tue Oct 16, 2018 10:20 am Post subject: Re: Where should the drain holes be in the door? |
Type 3's have drain slots in the doors at the Low points but they get plugged up with crud. I've drilled drain holes in the pans behind the seats at the Low points, when they got flooded! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Oct 16, 2018 12:04 pm Post subject: Re: Where should the drain holes be in the door? |
On Beetle doors, you should be able to see two holes when looking up from under the door . . . each being just in from the front/rear edge of the door . . . outboard from the weather-strip . . . . UNLESS someone has done repair work to the door . . . .
It is best to remove the door-cards and clean out the bottom of the doors . . . look for the holes.
Photo found by searching TheSamba Gallery . . .
_________________ Jesucristo es mi Seņor y Salvador! |
