beckyscutt Samba Member
Posted: Tue Oct 16, 2018 9:36 am Post subject: Roof Swap 73 Westfalia - Sunroof Model? |
I am looking at a bus that has had the original steel Westfalia roof replaced with a Sunroof model roof as the gutters were rotten.
For a 73 Model year was it correct to have the sunroof model fitted - will all of the furniture fit in height wise and is the hole in the roof in the correct place?
This is a UK RHD model |
SGKent Samba Member
Posted: Tue Oct 16, 2018 3:41 pm Post subject: Re: Roof Swap 73 Westfalia - Sunroof Model? |
normally sunroof models rot from the inside out even in dry climates. Humidity condenses inside the metal sandwich from the cold outside, and over time it eats away where the spot welds are. Make sure that top hasn't been painted in the last two or three years to be sure that rust isn't covered with bondo and paint. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Oct 16, 2018 3:52 pm Post subject: Re: Roof Swap 73 Westfalia - Sunroof Model? |
1968-1973 Westfalias with the full pop top option were based on a sunroof bus without the mechanisms or sliding panel installed, are you sure someone hasn't just removed the fiberglass pop top? Or did it begin life as a hard top with no roof opening?
The M code plate behind the LF seat will tell you how it came from the factory. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
