69mm crank in a 36hp
vandenabeele andries
vandenabeele andries is offline
PostPosted: Tue Oct 16, 2018 11:57 am    Post subject: 69mm crank in a 36hp Reply with quote
This has propably been asked before. But, is it possible to drop a OEM 69mm crank in a 36hp engine case? I have bought a 54 engine with a very bad crank. I wanne make this either a lager displacement 36hp or a standard one.
b-man
b-man is offline
PostPosted: Tue Oct 16, 2018 7:52 pm    Post subject: Re: 69mm crank in a 36hp Reply with quote
It won't fit, the OEM 69mm crank is made for a longer/larger 1300/1500/1600 crankcase that's completely different compared to a 36hp crankcase.
If the cheap and plentiful OEM 69mm crank was a drop-in then likely almost nobody would be buying expensive Okrasa 69.5mm cranks for their stroked 36hp engines.
Good luck with your engine build.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
PostPosted: Wed Oct 17, 2018 2:35 am    Post subject: Re: 69mm crank in a 36hp Reply with quote
Thx b-man. I got 5, 36hp engines in my shop. However I always wanted to build a "more pleasant engine" that looks stock.
Im not using a 60 year old second hand crank. Ive seen lots of cranks cracked with magnaflux. Reading this forum I found WW sells brand new counterweighted ones for 499.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111198600
This mean i could potentially bump it to a max of 1500cc.
