heiko910 Samba Member
Joined: November 15, 2013 Posts: 221 Location: Gardnerville, NV
Posted: Tue Oct 16, 2018 1:25 pm Post subject: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Hi there,
I have an issue with my 77 Bay window and I am running out of things to check.
1977 VW type 2 with a 2.0 Fuel injected type 4. All stock.
My Bay window runs and idles great, pulls strong. It has been perfectly reliable until it started getting a highspeed hiccup between 3000- 3800rpm.
It is not miss firing, at least it is not making the typical miss fire noises.
It is just bucking in that RPM range (very intermittent). It will keep accelerating even through those hiccups. It only does it when the engine is under heavy load (i.E. up hill, strong headwind). It runs fine and has no signs of hiccups on level road. Neither will it show any indications when revving it when parked.
I have checked everything that I could come up with.
I have change spark-plugs and wires, I have changed the electronic module (i have multiple, one compufire, one pertronix) in the distributor. I have tested the mechanical and the vacuum advance for proper function. I have tested for vacuum leaks with a smoke generator. I have switch the AFM with a backup that I have. I have tested for fuel pressure at the fuel rail and just because I could changed the fuel filter and the fuel pump.
I have checked all fuel and ignition related wiring. I have lubed the distributor. I have checked timing and advance. I have done a valve adjustment. The needle of my tachometer is not affected by the bucking which leads me to believe that it is not ignition related.
It only does it in the above mentioned RPM range. Could it be the mechanical advance?
I have already read all topics here on thesamba and any other webpage about related topics but so far I haven't found the smoking gun
If anyone has suggestion I would appreciate your help.
thanks,
Heiko |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Oct 16, 2018 1:47 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Sounds like it's a lean misfire (surging).
What did the fuel pressure check out at?
How accurate/reliable is your fuel pressure gauge? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
SGKent Samba Member
Posted: Tue Oct 16, 2018 2:49 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
quick smoke test to be sure there are no vacuum leaks
booster test to be sure it isn't leaking (2 minute test is fine)
Check timing with timing light to see if it flickers or bounces at 3000 - 3800 RPM. If you have a dwell meter and are using points put the dwell meter on it and see what the dwell is. If you have an electronic ignition or different coil other than stock or the good blue one it can be the cause because the ECU relies on the coil primary pulses to set up the injector pulses.
Anything else would be an outlier like loose wire that vibrates at that speed, timing too far advanced causing pinging / detonation etc., loose connector on ECU/AFM/injector that vibrates at the RPM etc. Don't think it would be in the mechanicals because valve / lifter float etc gets worse with higher RPM. It wouldn't be a come and go thing. Having an issue like that at peak torque could point to an ignition or timing issue. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
timvw7476 Samba Member
Posted: Tue Oct 16, 2018 2:52 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
the short hoses (4) where the intake tubes join the intake manifold?
check there for vacuum leak(s).
other than swapping points & condenser for compufire, can't think of any else. |
Posted: Tue Oct 16, 2018 3:03 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
I would begin by dumping a bottle of FI cleaner into the gas tank and see what they does for you.
A clogged fuel filter may not let enough fuel reach the engine under high load, high rpm operation.
Yes as others said, check for vacuum leaks. |
Posted: Tue Oct 16, 2018 3:41 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
udidwht wrote: |
How accurate/reliable is your fuel pressure gauge? |
Lean misfire? I just check idle mixture since I have a CO tester.
Fuel Pressure is around 29-30 psi, with regulator disconnected it jumps to 36psi. Gauge is average quality.
Possible that the tank outlet pipe is clogged with something and under higher fuel demand the flow isn't adequate.
I'll drain the tank and take the sending unit out and check from the inside. |
Posted: Tue Oct 16, 2018 3:53 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
SGKent wrote: |
Anything else would be an outlier like loose wire that vibrates at that speed, timing too far advanced causing pinging / detonation etc., loose connector on ECU/AFM/injector that vibrates at the RPM etc. Don't think it would be in the mechanicals because valve / lifter float etc gets worse with higher RPM. It wouldn't be a come and go thing. Having an issue like that at peak torque could point to an ignition or timing issue. |
As stated in the OP I did a smoke test to check for vacuum leaks.
I did the test with the timing light at RPM and there was no indication of flickering.
I changed the distributor electronic trigger to check. I also changed the coil. I changed the rotor and cap at the same time.
do u think a hang up in the mechanical/vacuum advance could cause this? I checked all electrical connections between ECU AFM and ignition. |
Posted: Tue Oct 16, 2018 3:54 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
timvw7476 wrote: |
I'll do that and report back. |
Posted: Tue Oct 16, 2018 3:56 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Wildthings wrote: |
I almost constantly running some additive. Most of the time it is Marvels Mystery Oil. I changed the Fuel filter together with the fuel pump and even cut the old filter open which was completely clean.
I already did the vacuum leak check with a smoke generator. No leaks were found. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Oct 16, 2018 4:03 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Heiko- You say it's all stock. If "all stock" also means you still have the stock spark limiting rotor I'll bet that's your issue. We saw these damn things cause runability complaints constantly.
The other close second would be a wobbly points breaker plate. This was very common also and you'll find it with your timing light. Either the mark will dance around in the light at idle or it'll start dancing at about 3000 RPM and get worse. It'll advance OK but be all over the lot at steady speed. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Oct 16, 2018 4:30 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Tram wrote: |
The other close second would be a wobbly points breaker plate. This was very common also and you'll find it with your timing light. Either the mark will dance around in the light at idle or it'll start dancing at about 3000 RPM and get worse. It'll advance OK but be all over the lot at steady speed. |
My bus (77 2.0 FI) doesn't come stock with a rpm limiting rotor. I will for sure check for the wobble in the point breaker plate and keep you posted. I have however already done a couple rpm runs with the timing light and didn't notice any dancing or inconsistencies. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Oct 16, 2018 5:02 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Strange as it sounds I've seen this resolved a few times by replacing the TS2, couldn't hurt to try. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Oct 16, 2018 5:10 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
heiko910 wrote: |
Tram wrote: |
Actually, it did come with that rotor but most of them failed under warranty. We advised customers to discard them once the warranty was up. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
SGKent Samba Member
Posted: Tue Oct 16, 2018 5:26 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
1977 has the electronic limiter in the ECU.
The way the fuel system works, the excess is always circulating so the demand is the same on the circuit.
I would be running points and the original coil to troubleshoot this. The ECU totally relies on the shape of the coil wave to establish the baseline injector pulse. Change the shape of that wave and the ECU doesn't know how to deal with it. You can also change the condenser on the distributor is you have one.
We had a 1967 Chrysler 383 when I was in my teens. It would buck like a mule once in a while headed up one grade in San Diego. Chrysler did about everything they could trying to find the cause. Like yours it was RPM dependent. Finally after about the 10th trip they replaced the plug wires although the car only had about 15,000 miles on it. That was the problem. Had it not been a car that I drove sometimes, and had I not seen the issue and the time put into it I would not believe someone if they told me wires could fail that way. Likewise I replaced plugs on an Opel GT (NGK) and took a trip to San Francisco from LA about 2 weeks later. It started cutting out and dropping cylinders on the trip under the heaviest load. After looking at everything else I put the old plugs back in which I was lucky to have with me. Problem went away. Put the new plugs back in when we got home and the problem came back. Same plug number, just a bad batch. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
wcfvw69 Samba Purist
Posted: Tue Oct 16, 2018 8:29 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Another vote to put points and condenser back in it and try again. I know I've read before that certain FI's don't like those electronic modules.
The other thought was mentioned already. A loose electrical connection in the FI harness plugs. _________________ Contact me at [email protected]
The Samba member since 2004.
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Oct 16, 2018 9:08 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
I’ve had the rotor cause similar symptoms, but on a dual carb 1776 type one motor. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Wed Oct 17, 2018 1:48 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
SGKent wrote: |
We had a 1967 Chrysler 383 when I was in my teens. It would buck like a mule once in a while headed up one grade in San Diego. Chrysler did about everything they could trying to find the cause. Like yours it was RPM dependent. Finally after about the 10th trip they replaced the plug wires although the car only had about 15,000 miles on it. That was the problem. Had it not been a car that I drove sometimes, and had I not seen the issue and the time put into it I would not believe someone if they told me wires could fail that way. Likewise I replaced plugs on an Opel GT (NGK) and took a trip to San Francisco from LA about 2 weeks later. It started cutting out and dropping cylinders on the trip under the heaviest load. After looking at everything else I put the old plugs back in which I was lucky to have with me. Problem went away. Put the new plugs back in when we got home and the problem came back. Same plug number, just a bad batch. |
I have been running pertronix and Compufire for six years now and the problem just recently started. I already replaced the module in the process of elimination which excludes it as the source for the problem. I appreciate the input and will make sure that I recheck everything one more time. |
Posted: Wed Oct 17, 2018 2:02 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
heiko910 wrote: |
SGKent wrote: |
OK, so it's definitely NOT "all stock" as stated initially. What else is not stock? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Wed Oct 17, 2018 2:11 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
So you checked the fuel pressure while under heavy load between 3000 and 3800 rpm and it was good? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Oct 17, 2018 2:14 pm Post subject: Re: 77 Bay window 2.0FI hiccups between 3000 - 3800rpm |
Tram wrote: |
heiko910 wrote: |
SGKent wrote: |
OK, so it's definitely NOT "all stock" as stated initially. What else is not stock? |
You got me.
The air filter is not the original 40 year old filter anymore. I have changed the original oil a few time since new. The spark plugs are not the originals anymore. All these parts are not the originals anymore: Fuel line, double relay, intake manifold rubber boots, the AFM is a replacement (even though the old one wasn't bad), spark-plug wires are newer, the evap system lines are all new, the alternator belt is totally aftermarket, the injector seals are also aftermarket, the valve cover gaskets are newer, I also added a oil pressure sensor which is wired to a gauge and I added a CHT gauge.
You are right this is not stock at all. I would go as far as calling it highly modified.
The tires are not original either.
Does anyone have any technical inside on what my buses hiccup problem could be caused by without taking any offense on the huge amount of modifications I have done to my bus? |
