robcy04 Samba Member
Posted: Thu Oct 18, 2018 11:19 am Post subject: Rear A-Arm Pivot Bushing |
Is the stock rear A-Arm Pivot Bushing on a 79 SB Vert a press on, or more importantly a press off bushing? |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Thu Oct 18, 2018 12:24 pm Post subject: Re: Rear A-Arm Pivot Bushing |
Yes and yes. The original were press in (metal sleeved) therefore they required pressing (pounding) out. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Thu Oct 18, 2018 1:58 pm Post subject: Re: Rear A-Arm Pivot Bushing |
robcy04 wrote: |
Are you referring to the rear trailing arm?
Posted: Thu Oct 18, 2018 2:38 pm Post subject: Re: Rear A-Arm Pivot Bushing |
[quote="Dwayne1m"]
robcy04 wrote: |
Yes, that one. I swear that here in Central Florida taking anything to get pressed out they bill you like you need to pay off their Doctorate from Yale. |
Posted: Thu Oct 18, 2018 2:49 pm Post subject: Re: Rear A-Arm Pivot Bushing |
You can do the job with a few simple tools. |
Posted: Thu Oct 18, 2018 3:20 pm Post subject: Re: Rear A-Arm Pivot Bushing |
Thanks for the info. I plan on replacing them with urethane ones that do not require a press. Great write up. |
vamram Samba Member
Posted: Thu Oct 18, 2018 3:43 pm Post subject: Re: Rear A-Arm Pivot Bushing |
I used the Topline black urethane ones. They actually go inside of the metal shell of the original rubber ones. So you remove the center sleeve and rubber of the old ones, push in the topline ones. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Thu Oct 18, 2018 8:24 pm Post subject: Re: Rear A-Arm Pivot Bushing |
vamram wrote: |
I used the Topline black urethane ones. They actually go inside of the metal shell of the original rubber ones. So you remove the center sleeve and rubber of the old ones, push in the topline ones. |
WOW, that means no pressing. How hard is it to remove the center sleeve/rubber from the original ones? |
