Danwvw Samba Member
Posted: Thu Oct 18, 2018 4:37 pm Post subject: Porsche 924S |
Doing a Brake Job on my Porsche 924S and am wondering about what brake fluid and what grease and what brand of brake pads and rotors are good etc...
The Pelican forum does not seem to be getting any responses!
Front:
Rear:
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu Oct 18, 2018 6:02 pm Post subject: Re: Porsche 924S |
Mintex pads
Front D 209 MTX (928 351 942 00)
Rear D 210 MTX(928 352 942 00)
Zimmerman rotors
Front 911 351 041 20 (911 351 041 20 SP cross drilled)
Rear 944 352 041 02
DOT4 brake fluid _________________ Glenn
Member #1009
#BlueSquare |
Danwvw Samba Member
Posted: Fri Oct 19, 2018 7:08 pm Post subject: Re: Porsche 924S |
Pads: Porterfield Racing R-4s Pads! (The R is for Racing the S is for street these pads are trimmed and a little smaller over their racing counterpart. They are said to be noticeably better than Stock.)
Yes Got the Zimmerman's,
Castrol Dot - 4.
I think I ordered an aluminum neutral grease. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Danwvw Samba Member
Posted: Sat Oct 20, 2018 6:00 pm Post subject: Re: Porsche 924S |
Anyone know anything about rear caliper assembly. I Don't know where to set the plunger rotation on my Rear Disc that has the caliper on the back side of the disc. Right now I have it set to zero the directions show two different setups one at Zero and one at 20'
Here is a photo of how it was but I may have had it wrong from a couple years ago when I cleaned and lubed it. This is the one that was hanging up too.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Sat Oct 20, 2018 9:51 pm Post subject: Re: Porsche 924S |
i don't know for sure for your model, but ATE typically used an angle of 20 degrees as shown below:
Eyeballing, this looks like the same angle on my VW Type 3 pistons. I would guess ATE stuck with this measurement; I've seen it referenced for the 911, too. |
Danwvw Samba Member
Posted: Thu Oct 25, 2018 6:34 pm Post subject: Re: Porsche 924S |
Looks like it just goes such that the center of the raised part of the plunger press surface is centered right in the direction the rotor turns, makes sense! I will take a closer look at where the calipers mount when the e-brakes come and I can put it back together. Well I think you are right The calipers are positioned such that it would be centered at about 20' Degrees on the This Porsche, Only thing though is, I forgot and left it at 0' Degrees on the rear, I did set the front at 20' Degrees. We will see how it acts I better set the other rear side the same 0's when I do it tomorrow. Thanks
(Note! Everything is different with the Porsche than the diagrams above but the Idea is the same.)
Left Rear:
Left Front:
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Oct 26, 2018 2:01 pm Post subject: Re: Porsche 924S |
My 6X14 Zenith knockoff wire wheels were made for a 924 w/4X112 bolt pattern. I had them drilled for 4X130 too. Stacked in the barn w/tires waiting for a new owner w/$600.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Sat Oct 27, 2018 2:48 pm Post subject: Re: Porsche 924S |
You are selling those wheel? |
Posted: Sat Oct 27, 2018 3:24 pm Post subject: Re: Porsche 924S |
Yeah I'm running 2.0 liter Fuchs now, but I did run the Zenith wire wheels for 2-3 years.
oprn Samba Member
Posted: Sat Oct 27, 2018 4:13 pm Post subject: Re: Porsche 924S |
Those wire wheels are sweet! If only I was closer or if there was some reasonable way to ship them...
Can tubeless tires be run on them? |
Posted: Sat Oct 27, 2018 4:58 pm Post subject: Re: Porsche 924S |
I bought new tubes to run in tubeless tires because I didn't want any leaks! _________________ https://imgur.com/user/FisherSquareback/posts
Danwvw Samba Member
Posted: Sat Oct 27, 2018 7:01 pm Post subject: Re: Porsche 924S |
Hey, Mike, I think I talked to you once at Woodburn! The car you show is very nice looking with those. Yeah, they are for the bug too right, like a 68 or later? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
oprn Samba Member
Posted: Sun Oct 28, 2018 5:43 am Post subject: Re: Porsche 924S |
Those would look so good on my Manx copy Buggy. I have never seen a Buggy with wires either so it would stand out in a crowd for sure! The only issue is they are a little narrow to maintain the classic "bigs and littles" look. |
Danwvw Samba Member
Posted: Sun Oct 28, 2018 1:06 pm Post subject: Re: Porsche 924S |
KTPhil wrote: |
Have any of you Type 3 owners done the Disc Brakes on them and can post photos of where the Calipers mount?
I still am not sure if my rear caliper plungers should not be at Zero because of Porsche caliper mounting is a little different than at 90 degrees to the axles. Maybe the fronts need 20' degrees they are mounted a little above.
1988 Porsche 924S Left Rear Disc Brake:
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Oct 28, 2018 2:50 pm Post subject: Re: Porsche 924S |
The step angle has nothing to do with the caliper orientation on the axle, it's about angle of attack Vs: the disc's rotation, if the caliper is square to the disc (like in your pic) then I'd go with the 20*. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Danwvw Samba Member
Posted: Sun Oct 28, 2018 3:32 pm Post subject: Re: Porsche 924S |
What? That Type 3 Diagram above is square but the Porsche 924s calipers are positioned about 20' degrees up in front and 20' degrees down in the back.
By the way, Thanks for the reply. I have not had much experience with Disc Brakes and I am still thinking I should set the plungers straight Zero in line with the caliper which looks like it would place the plungers high edge trailing square on the rotors which would be correct in my thinking?
Left Front:
Left Rear:
Posted: Sun Oct 28, 2018 3:58 pm Post subject: Re: Porsche 924S |
Caliper position doesn't matter, it can be 2:00, 4:00, 8:00 or any place that fits, if you draw a line from the hub center out across the caliper it will always be 90* to the pads, and each end of the caliper frame will be equally spaced away from the rotor edge. No matter where the caliper is positioned it's pads are still oriented parallel to the discs rotation, the step in the piston optimizes pad contact or squeeze to that angle, not where the caliper is mounted and should be 20* off from that imaginary line.
Put them in any way you like, I'm sure it'll stop, but I suspect it stops best when the pistons are oriented correctly.
I've always found it strange that Porsche didn't use the retainer plates like buses do (at least that's what Porsche "experts" tell me and I've never found any installed), I can never get a good answer when I do brakes on them. But why bother stepping the piston if it doesn't work better situated a certain way? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Danwvw Samba Member
Posted: Sun Oct 28, 2018 4:09 pm Post subject: Re: Porsche 924S |
I see what you're saying. So 20's CW from zero on both? That would put them pressing further out on the disc right? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun Oct 28, 2018 5:27 pm Post subject: Re: Porsche 924S |
Yes, with the stepped down section facing the oncoming disc in normal driving direction. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Oct 29, 2018 9:19 am Post subject: Re: Porsche 924S |
busdaddy wrote: |
Yes, with the stepped down section facing the oncoming disc in normal driving direction. |
The step is most likely to keep the leading edge of the pad from wearing and/or from making noise. A lot of brakes today have biasing clips, springs or offset pistons to keep leading edges from contacting first. MB and others use different diameter pistons in their 4 and 6 pot calipers to accomplish this. in testing I have seen brakes with up to 2mm of taper wear between the leading and trailing edges of pads. |
