chrisdiehl Samba Member
Joined: October 10, 2011 Posts: 183 Location: middle ga
Posted: Thu Oct 18, 2018 9:08 pm Post subject: Tall shifter for 65 |
I can't weld. Does anyone make and sell tall shifters that will fit in a 65 beetle? About the height to the top of the dash...maybe a little shorter. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Thu Oct 18, 2018 9:22 pm Post subject: Re: Tall shifter for 65 |
Well, Type 2's had taller shift levers, you might have a look at those
https://www.thesamba.com/vw/classifieds/search.php...ton=Search _________________ Andy T.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Oct 18, 2018 10:05 pm Post subject: Re: Tall shifter for 65 |
A stock shifter (since you say you don't weld)? You're going to need a short throw kit too. I'd drop off two stock shifters, instructions and a dozen donuts at the local trade school or welding shop. A new long one will be done by noon. _________________
EverettB wrote: |
FU#5 |
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Fri Oct 19, 2018 8:50 am Post subject: Re: Tall shifter for 65 |
Definitely going to need short throw kit. I just did this in mine. Any local welder can do it but be prepared to "adjust" the bends once in the car. A torch will heat it so you can easily tweak it once installed. I used the empi kit https://www.v-dubstore.com/product-p/e4500.htm
_________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Fri Oct 19, 2018 7:32 pm Post subject: Re: Tall shifter for 65 |
I added an extension to mine. Cost a few bucks and works a charm.
_________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
EVfun Samba Member
Posted: Mon Nov 05, 2018 11:57 am Post subject: Re: Tall shifter for 65 |
scottyrocks wrote: |
Where can I find that extension? The shape would be perfect in my beach buggy and it looks to be for the small 7mm thread shifter. _________________
Wildthings wrote: |
KTPhil Samba Member
Posted: Mon Nov 05, 2018 12:02 pm Post subject: Re: Tall shifter for 65 |
There are several styles (and thread sizes), so google "beetle shifter extension" and pick your poison. |
stinkbug69 Samba Member
Joined: February 25, 2009 Posts: 37 Location: georgia
Posted: Sun Feb 20, 2022 9:17 pm Post subject: Re: Tall shifter for 65 |
MMW wrote: |
any issue with the shifter moving around, popping out of gear or flopping around while in gear and driving down the road? |
Geier Samba Member
Joined: December 20, 2005 Posts: 187 Location: San Jose Ca.
Posted: Mon Feb 21, 2022 9:34 am Post subject: Re: Tall shifter for 65 |
Years ago I ordered an extension from some outfit for my 65 T1. When I opened the package there was an offset extension for a T2 in the bag. I was bummed for a bit but installed it anyway. Today so many years later I love the slight dogleg towards me with just the right amount of rise to make shifting so much more comfortable. Don’t be afraid of the T2 extension. Good luck. |
