MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Fri Oct 19, 2018 11:16 am Post subject: How to disable a 2012 Jetta? |
Long story but is there a simple way to make a 2012 Jetta not be able to drive that can be easily reversed when I need the car? Maybe make it so the shift lock won't release? This has to do with my father who has dementia. Tried just taking the keys but that caused major issues. _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
Joined: August 31, 2013 Posts: 12847 Location: North Carolina
Posted: Fri Oct 19, 2018 11:24 am Post subject: Re: How to disable a 2012 Jetta? |
Thin piece of plastic between the battery clamp & post.
Remove one of the big ass fuses in the fuse panel behind the battery, remove them one at a time until it doesn't start.
Find the screw in the middle of the fuse panel behind the battery, loosen it & pull up on the fuse panel, this will unplug the whole unit from the car, replace cover. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Fri Oct 19, 2018 11:27 am Post subject: Re: How to disable a 2012 Jetta? |
Sorry to hear about your challenges.
I would agree with the battery clamp suggestion. |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Thu Dec 13, 2018 10:13 pm Post subject: Re: How to disable a 2012 Jetta? |
September 11, 2001, I barrowed my Mother's car, and I never returned it.
There were no airplanes, and I needed to return to work.
She had wrecked it twice, second time she nearly killed someone else.
She had Alzheimer’s, and never accepted the diagnosis, because she had no short term memory by the time this happened.
We had spent the end of August moving her to Olympia, Wa. so my Sister could care for her.
Funny thing is she had no problem remembering I stole her car.
This is something that your Parent will never forgive you for doing, but it has to be done. _________________ Good Luck
Al |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Wed Jan 02, 2019 11:34 am Post subject: Re: How to disable a 2012 Jetta? |
Old thread - adding to my In Law experience
We pulled a fuel pump relay on our Volvo to stop a relative in need of not-driving. _________________ .ssS! |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Mon Jan 28, 2019 10:17 am Post subject: Re: How to disable a 2012 Jetta? |
Battery disconnect switch.
Bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Tue Jan 29, 2019 9:08 am Post subject: Re: How to disable a 2012 Jetta? |
where is the fusebox? you can replace a fuse with a tap that extends the wires so you can add a hidden switch (and fuse) w/o making a perm change to the wiring in the vehicle.
use 2 of these, one on each leg.. of a BLOWN fuse..
then wire off the interrupted circuit.
Abscate wrote: |
