Top heat exchanges - removal.
BJT
BJT is offline
PostPosted: Fri Oct 19, 2018 1:30 pm    Post subject: Top heat exchanges - removal. Reply with quote
Has anyone put in an exhaust that removed, or didnít have, the top smaller heat exchangers, but kept the heater boxes and ran the tubes from the fan shroud to the heater boxes? How much, if any, loss of heat is there from doing this?
mondshine
mondshine is offline
PostPosted: Fri Oct 19, 2018 1:48 pm    Post subject: Re: Top heat exchanges - removal. Reply with quote
The CSP (225 165) stainless steel heater hose fitting is the nicest solution to this I have ever seen.
I've had them on my car since installing a Vintage Speed exhaust.
Having seen the photo, it's obvious that the creative fabricator could just make these, however the price was reasonable for those who don't want to dick around with it.
I used my original VW band clamps on the heat exchanger ends because they are about an inch wide, and seemed to be more substantial than the clamps furnished with the CSP kit.
There is no appreciable loss of heat.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C31-255-165-CSP
BJT
BJT is offline
PostPosted: Sat Oct 20, 2018 10:15 am    Post subject: Re: Top heat exchanges - removal. Reply with quote
Those look perfect. I was going to just run the heater tubes all the way to the boxes, but these look like a better option. Thanks.
