ManFromNapa Samba Member
Joined: March 08, 2012 Posts: 184 Location: United States
Posted: Fri Oct 19, 2018 6:34 pm Post subject: Adjustable Beam and Flipped Spindles |
I'm going to put an adjustable bean on the front of my bus. I don't want to lower too much. The front end is just a little high. On the back I have adjustable spring plates.
If I install flipped spindles, will I be able to use the beam to raise to stock height? Or near to it? _________________ North Bay Air Cooled - VW Club in Napa, CA
http://www.northbayaircooled.com/
Check out my band, Thru The Haze
http://www.thruthehazeband.com/ |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Oct 20, 2018 3:02 am Post subject: Re: Adjustable Beam and Flipped Spindles |
Depends how the beam is built The highest setting on my Wagenswest beam is close to stock height. Flipped spindles are 3½ inches lower than stock. I would go with just an adjustable beam if you want to lower it less than 3½ inches. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Sat Oct 20, 2018 6:42 am Post subject: Re: Adjustable Beam and Flipped Spindles |
How much are you planning on lowering it? And , are you running adjustable spring plates on reduction boxes in the rear?
My opinion is that if you have reduction boxes, don't flip the spindles. Keep it all running where it should be. Adjust the rear to have 0 camber and set the front to match that ride height.
Once you start to lower, it's a slippery slope which the next step is 3 1/2" down. Which is fine too. You just have to decide if you're going to listen to the Angel or the Devil on your shoulder.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
