Zundfolge1432 Samba Member
Posted: Fri Oct 19, 2018 8:06 pm Post subject: Quick clean |
I’ve been using this plastic media to clean carbs and fuel pumps and other parts where you cannot risk damaging the factory finish or plating. I decided to try it on a case because this one will have all the oil galley plugs removed and passages brushed and swabbed clean. Others have used baking soda blast and this is similar and unlike other media this does not imbed in the material.
So it goes quick from dirty to clean in about five minutes here are before and after pics.
Same engine moments later
Deebs Samba Member
Joined: June 23, 2018 Posts: 248 Location: Chattanooga, TN
Posted: Fri Oct 19, 2018 8:28 pm Post subject: Re: Quick clean |
Holy smokes.
Amazing what blasting can do in a short amount of time! |
sb001 Samba Member
Posted: Fri Oct 19, 2018 10:22 pm Post subject: Re: Quick clean |
Wow...
are u going to do that on those 6 engine cases you are about to pick up for $200? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Sat Oct 20, 2018 5:38 am Post subject: Re: Quick clean |
Got a name/link for the media you used? _________________ "Albatross"! |
gt1953 Samba Member
Posted: Sat Oct 20, 2018 6:19 am Post subject: Re: Quick clean |
Nice the before and after. So where is the Middle located as I would bet you will get some folks want to bring you stuff the do. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Fiddlestyx Samba Member
Posted: Sat Oct 20, 2018 8:11 am Post subject: Re: Quick clean |
Since the corrosion has already started, how do you plan on stopping it? _________________ 1983 Vanagon Westfalia Air-cooled
1973 Super Beetle |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Sat Oct 20, 2018 9:15 am Post subject: Re: Quick clean |
Fiddlestyx wrote: |
Since the corrosion has already started, how do you plan on stopping it? |
I would imagine wiping the case down with some type of oil/lubricant will help.
Nice work Z. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
sb001 Samba Member
Posted: Sat Oct 20, 2018 10:46 am Post subject: Re: Quick clean |
gt1953 wrote: |
So where is the Middle located as I would bet you will get some folks want to bring you stuff the do. |
Why an abandoned warehouse with a crazed lunatic of course _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Sat Oct 20, 2018 1:55 pm Post subject: Re: Quick clean |
Fiddlestyx wrote: |
If engine was put into service quickly it might just cover itself with oil mist but I’m thinking Gibbs metal treatment or possibly Corban. Applied properly a light coat of Corban would make translucent gold finish just like when it was new |
smeed Samba Member
Joined: July 02, 2017 Posts: 17 Location: Connecticut
Posted: Sat Oct 20, 2018 2:25 pm Post subject: Re: Quick clean |
sb001 wrote: |
gt1953 wrote: |
Why an abandoned warehouse with a crazed lunatic of course |
They probably build jet engines there |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Oct 20, 2018 2:30 pm Post subject: Re: Quick clean |
smeed wrote: |
You sir get a cookie for the most correct answer! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
