Foxy brown Samba Member
Posted: Sat Oct 20, 2018 9:30 am Post subject: Distributor |
Looking at replacement distributor for 1978 vw 2.0l fuel injected. Pertronix kit or screamer kit? Looking for a direct replacement kit |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76903 Location: Sneaking up behind you
Posted: Sat Oct 20, 2018 10:10 am Post subject: Re: Distributor |
I would not get a complete Pertronix distributor, their quality is not the equal of the original Bosch. If you have the original 205P, I would get it rebuilt. Then you can decide if you want to stick with points or install a Pertronix module inside of it.
I along with Bill rebuild the original distributor.
You mentioned a "screamer", the original "Screamer" was sold by Bosch and included a 019 mechanical distributor along with a coil. When the 019 was discontinued, Bosch used the 009 distributor which is also mechanical only. I can only assume that any new screamer uses a aftermarket 009 copy. DO NOT GET ONE, first they are crap and secondly your 2.0l FI Bus needs a distributor that has both vacuum and mechanical advance like the 205P. _________________ Glenn
Member #1009
#BlueSquare |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Sat Oct 20, 2018 3:02 pm Post subject: Re: Distributor |
Glenn I thought you just did mechanical advance dizzy's? Good to know you do the vacuums too. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
wcfvw69 Samba Purist
Posted: Sat Oct 20, 2018 3:38 pm Post subject: Re: Distributor |
An 022-905-205S is also a good fit and was used in the late bays. It's an SVDA distributor that's excellent after restoration.
I do have some in stock if you need one.
X2 on what Glenn says about any of the new Chinese distributor copies. Poor quality, materials and they simply don't work right. I'd put a restored German Bosch back in it like when it was delivered new. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Oct 20, 2018 4:19 pm Post subject: Re: Distributor |
Shameless self promotion.
That said, it would be the correct move _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Oct 20, 2018 7:12 pm Post subject: Re: Distributor |
aeromech wrote: |
That said, it would be the correct move |
Putz!
Um, it's called Marketing Mr. pot meet kettle.. _________________ Contact me at [email protected]
Posted: Sat Oct 20, 2018 7:28 pm Post subject: Re: Distributor |
Looks like you and Stu should start your own sensitivity clinic _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sat Oct 20, 2018 7:31 pm Post subject: Re: Distributor |
wcfvw69 wrote: |
X2 on what Glenn says about any of the new Chinese distributor copies. Poor quality, materials and they simply don't work right. I'd put a restored German Bosch back in it like when it was delivered new. |
A Pertronix SVDA will not work optimally out of the box. It must be taken apart cleaned and lubed properly. Then you must check the vac can and verify that it holds vacuum and when the advance moves and stops.
If it all checks out well it will work far better than a cheap 009. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sat Oct 20, 2018 7:36 pm Post subject: Re: Distributor |
aeromech wrote: |
Looks like you and Stu should start your own sensitivity clinic |
Don't worry Gary, we've both hired a master therapist. Maybe you've heard of him? _________________ Contact me at [email protected]
