70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Sat Oct 20, 2018 9:47 am Post subject: Did my local starter shop do me wrong? |
I was having intermittent starter issues with an original Bosch 211-012-013 starter so I took it in to the local starter/generator rebuild shop. I told them it sounded like the solenoid was failing but that was just a guess. The employee took it in the back and I heard him do a couple bench test runs. It sounded like it was slowing down over each 3-5 second run. He said it sounded like the motor was failing and they’d need to pull it apart. He called back the next day and said my bushing must be bad because the shaft was not properly supported and it had worn the case.
I have since read that the original starter can’t be bench tested unless it is connected to the transmission housing. I am fairly certain (although not sure) that this shop wouldn’t have a test stand for a VW starter, unless there is a universal stand that supports the shaft. I am guessing that when they ran the initial test, the damage to the case was done… that’s the noise I heard, with the unsupported shaft hitting the case and getting further out of round the longer it ran. Does that sound like a reasonable assessment? Just trying to educate myself before I go back and talk to them. _________________ 1970 Crew Cab |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
70Crew Samba Member
Posted: Sat Oct 20, 2018 11:10 am Post subject: Re: Did my local starter shop do me wrong? |
Well, I kind of assumed these were 2 separate issues, and I have been taken to task for my posts being too long. So... I did separate these intentionally, whether that was appropriate or not. _________________ 1970 Crew Cab |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Oct 20, 2018 11:14 am Post subject: Re: Did my local starter shop do me wrong? |
Yep. They screwed you. Ask to see their test rig.
I suggest you buy the self supported auto trans starter. I got one recently from Amazon. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sat Oct 20, 2018 11:18 am Post subject: Re: Did my local starter shop do me wrong? |
aeromech wrote: |
I suggest you buy the self supported auto trans starter. I got one recently from Amazon. |
Better yet
No tax and free shipping
https://www.autohausaz.com/pn/SR17X
Oops, they want a core. Amazon didnt _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
70Crew Samba Member
Posted: Sat Oct 20, 2018 11:39 am Post subject: Re: Did my local starter shop do me wrong? |
aeromech wrote: |
aeromech wrote: |
Better yet
Oops, they want a core. Amazon didnt |
Actually, I did replace it with the auto starter. Bought it from Amazon last week for $104 shipped, no core. Unfortunately I am also having issues with that, as documented in this separate thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= _________________ 1970 Crew Cab |
wcfvw69 Samba Purist
Posted: Sat Oct 20, 2018 3:47 pm Post subject: Re: Did my local starter shop do me wrong? |
I'm glad to see you use your local starter repair shop first before going to amazon. Starter/alternator/generator shops are going to disappear rapidly if we don't support them with our business. Well have to ship everything around the country to get something fixed. Hopefully, yours is going to take care of your problem, even if they messed it up.
The last time I bought a new Bosch Generator was 10-15 years ago. I was in a hurry for a generator. I bought a new Bosch made in Mexico one. Out of the box, it was clear the quality was much lower than the original German version. The brushes didn't slide down the holders well and I kept getting a gen light on. I finally pulled the brushes and installed almost new used German ones along with the German brush springs that were much thicker and better quality. The problem went away. I did notice how flimsy the brush holders were too along with the cheap brush springs.
I kept my German one and had it rebuilt. No issues at all post rebuild. _________________ Contact me at [email protected]
The Samba member since 2004.
