CakeDiesel Samba Member
Joined: August 31, 2018 Posts: 44 Location: Sidney, BC
Posted: Tue Nov 03, 2020 10:25 pm Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
Here's me and the little gal putting in a late night in the shop. Love you Allison. Hope to get a lot of trips in together.
Posted: Tue Nov 03, 2020 10:29 pm Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
That brings us roughly to where the van sits now.
Recently got some mercedes wheels mounted with some BFG all terrains. I think I'll use them for a year or two and go up a size. I'll have to see how they perform first.
I did have my eyeballs on some goodyear duratracs in a ~29inch tire but these nice used BFGs came up right as I was looking.
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Wed Nov 04, 2020 7:14 am Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
Excellent attention to detail and amazing workmanship! You have top-notch skills sir.
At first glance I thought the oil pan and engine carrier were sourced from a vendor. Gorgeous. Thanks for sharing. _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!) |
Zeitgeist 13 Samba Member
Posted: Wed Nov 04, 2020 8:13 am Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
Beautiful work! _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
valvecovergasket Samba Member
Posted: Wed Nov 04, 2020 9:38 am Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
Escorial Syncro wrote: |
At first glance I thought the oil pan and engine carrier were sourced from a vendor. Gorgeous. Thanks for sharing. |
x2
awesome work _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Wed Nov 04, 2020 9:42 am Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
CakeDiesel wrote: |
Really nice work, man, absolutely beautiful. Fantastic that you're working on the van with your daughter already! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Wed Nov 04, 2020 9:47 pm Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
Great design and execution, although now I feel like I'm really slacking on my own projects, ha!
I'll be curious to see how that trans works out. What else was required for that to be flipped? I assume you had to modify the oil fill, drain, and breather?
Keep up the momentum! _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Posted: Sat Nov 07, 2020 2:30 pm Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
uberaudi wrote: |
Keep up the momentum! |
Thanks for the kind words and good questions.
The transmission flip doesn't require a ton of work, there are 2 main challenges IMO.
1) An adapter plate must be made
Sort of goes without saying, but a tough design challenge. I touched on these challenges on page 1.
2) Shifting linkage
I have seen a few solutions to this. Some are happy to modify the stock manual linkage, but it puts the shifter pattern in reverse (1st gear to the right)
I made a system using some push-pull cables and a custom shifter, facing backwards. I dont have any photos of the shifter, but you can see one of the grey cables in the photo below, coming off the transaxle mount.
There are some other smaller challenges like drill and tapping a new breather hole, selecting the right axles (the angled is increased) and slave cylinder hoses. I used 930 CVs because of the diesel torque and I wanted to run big tires, 944 CV's would also be appropriate. |
GreggK Samba Member
Joined: May 17, 2008 Posts: 898 Location: Colorado/Philidelphia
trentb512 Samba Member
Joined: April 30, 2017 Posts: 12 Location: Fort St. John, BC
Posted: Mon Mar 29, 2021 10:12 am Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
How has the engine and transmission been working out for you? I keep wavering between rebuilding a 091 or swapping in a flipped passat transmission when I swap in an ALH and would love to hear some feedback from this side of the pond!
Beautiful work by the way! _________________ 84 Westfalia
1.9 WBX
Manual Transmission |
Posted: Tue May 04, 2021 10:05 pm Post subject: Re: Adventure Build - 1983 Westfalia TDi Restomod |
Uuupdate, uuupdate! _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
