Sofia74 Samba Member
Posted: Sun Oct 21, 2018 3:03 pm Post subject: Looking for Paint Samples |
We are interested in painting our 1974 KG Coupe. We are looking at a couple original VW colors, including Dolphin Blue, Iris Blue and others. My question is can we get samples of a couple different colors without buying an entire quart? Quart seems to be the smallest size available. Would ideally like to see some printed samples to hold and stare at if possible.
Any ideas?
Thanks, Matt |
Cour6396 Samba Member
Joined: August 04, 2008 Posts: 49 Location: Vancouver, Wa
Posted: Sun Oct 21, 2018 3:33 pm Post subject: Re: Looking for Paint Samples |
Hi Matt.....
If you know the exact paint code, and you can find a dealer for supplying paint, most paint stores can provide you a sprayput of the color.
Sean |
Posted: Wed Dec 05, 2018 4:17 pm Post subject: Re: Looking for Paint Samples - update |
Update: Local PPG store was able to give me one-ounce samples of Gulf Blue (Codes L390 / 12449) and Neptune Blue (codes L50K / 13454).
They could not find in their database Dolphin Blue or Bernina in spite of the fact that I had the "PPG Paint Code". I had Dolphin Blue as L337 / 31883 and Bernina as L431 / 12130. I found that strange since the one code was specifically a PPG code.
At this point I am looking for a supplier for samples to help us decide the color for our 1974 KG coupe. Then of course the larger quantity.
Any ideas? Thanks, Matt |
Posted: Sat Dec 15, 2018 3:05 pm Post subject: Re: Looking for Paint Samples - UPDATE |
I was able to find Dolphin Blue and Bernina Blue on a website called PaintScratch.com. I got the one ounce bottle but they had quarts and gallons too in case anyone else in looking. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Mon Dec 17, 2018 12:29 pm Post subject: Re: Looking for Paint Samples |
The problem with just getting samples from anyone.....is that you need to know exactly WHOSE paint system they were made with.
Each paint brand uses different pigments, binders, solvents in their lines. No two are exactly alike.
So taking a paint # code that was originally formulated say by Glasurit.....and looking at the same formula made in PPG.....may not be the exact same color when applied. Usually if a mfg has gone through the trouble to match an existing color formula made ny a different mfg.....they can get pretty close if they use a spectrophotometer....and most do.
Thats....IF.....the pigments in their toners (which WILL be different than the original mfg) have the range to allow them to hit that color. It gets more difficult if the original color formula is decades old. In many cases the original pigments are no longer in use or available.
So just be sure if you buy small spray or brush samples.....that they are made in a brand name paint and series you can buy....and not some no-name one off. Ray |
glenn87 Samba Member
Joined: October 11, 2009 Posts: 5 Location: Richmond Va
Posted: Mon Dec 17, 2018 12:59 pm Post subject: Re: Looking for Paint Samples |
i have sample from them for hoizon blue waay to gray cheap though just make sure your painter can match it |
Posted: Mon Dec 24, 2018 5:07 pm Post subject: Re: Looking for Paint Samples - next questiopn |
Good news is I will not be matching but painting the whole car.
So my next question is about PaintScratch paints. Are they good quality? We found a couple VW colors from them that we have so far not found anywhere else. And they sell in gallon sizes. |
