H30/31 or 30 pict 1
balljoint
balljoint is offline
PostPosted: Mon Oct 22, 2018 11:28 am    Post subject: H30/31 or 30 pict 1 Reply with quote
I have a 30 pict 2 that runs but needs replacing due to leaky shaft etc.
My distributor is a Brazilian 009 that I'm reusing as I have a lot of other stuff to sort out on this car and cannot focus on changing both carb and dist at the same time.
I've done lots of research and see the H30/31 or the 30 pict 1 with power circuit plays best with the 009 so it's gonna be one of these but I'm leaning more towards the H30/31 because of the larger venturi and should be better suited for my stock 1600DP.
Opinions?
Cusser
Cusser is offline
PostPosted: Mon Oct 22, 2018 1:18 pm    Post subject: Re: H30/31 or 30 pict 1 Reply with quote
I run a 30/31 PICT (that I rebuilt myself as a precaution since wan't used for a decade) on a stock dual port manifold on the 1600cc DP engine I rebuilt 1.5 years ago. I use a vintage German 009 with it too. Runs good.
balljoint
PostPosted: Sat Nov 03, 2018 6:33 am    Post subject: Re: H30/31 or 30 pict 1 Reply with quote
Yes I see you have had good success with that set up.
Anyone else?
mikedjames
mikedjames is offline
PostPosted: Sat Nov 03, 2018 11:27 am    Post subject: Re: H30/31 or 30 pict 1 Reply with quote
Opinions?
You could re bush the 30 pict 2, either buying replacement bushes or standard fitting metric engineering bushings.
Neither of the carburettors you have are really ideal for a 1600DP. But then with an 009 as well you arent getting the most from it either so I suppose it doesnt matter ..
Ancient vehicles and vessels
balljoint
PostPosted: Sat Nov 03, 2018 3:33 pm    Post subject: Re: H30/31 or 30 pict 1 Reply with quote
The pict 2 isn't ideal either! Confused
gt1953
gt1953 is offline
PostPosted: Sun Nov 04, 2018 7:02 am    Post subject: Re: H30/31 or 30 pict 1 Reply with quote
Just do yourself a favor and runt he H30/31. Flexible carb actually. Running that on my stock single port 1600cc with a Bosch 205 M vacuum distributor. Ya the 009 will work as long as it is a good German one. Another option is to send the carb to Tim Volkzbiz and when it is returned to you it will be as good as or better then New Old Stock =NOS.
72 type 1
72 Squareback
balljoint
PostPosted: Sun Nov 04, 2018 7:34 am    Post subject: Re: H30/31 or 30 pict 1 Reply with quote
Whatever carb I decide on I will be getting it from Tim.
Even if I go the H30/31 personally I feel one from him will be better because of the upgraded bronze throttle shaft bushes....don't know what the new ones come with tho.
Not too keen re-using the 30 pict 2 because of the know issues.
