Harmonic Damper?
BlissBignall
BlissBignall is offline
PostPosted: Mon Oct 22, 2018 2:27 pm    Post subject: Harmonic Damper? Reply with quote
I was driving down the road today, and hit a bumpy section. The front end of the car started vibrating and bouncing uncontrollably. Once I had slowed down to a crawl, it settled down. This has happened a couple times today, but never before.
Would I be correct that I probably need to replace the harmonic dampener (that horizontal shock absorber in the front suspension)? my front shocks are nice and firm, so I know that's not it.
Thanks in advance!
1963 Beetle...My mom's car that got sold in 2012
1969 Beetle...That was fun!
1972 Beetle...Never ran right
1974 Thing....Daily driver on sunny days
hobie16
hobie16 is offline
PostPosted: Mon Oct 22, 2018 3:58 pm    Post subject: Re: Harmonic Damper? Reply with quote
It's a steering dampener.
I'd check wheel balance too.
Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anythingís going to happen, itís going to happen out there.
---Captain Ron
mondshine
mondshine is offline
PostPosted: Mon Oct 22, 2018 4:23 pm    Post subject: Re: Harmonic Damper? Reply with quote
The death wobble!
It usually occurs right around 50 MPH.
Check all of the steering parts; ball joints, tie rod ends, steering gearbox, front wheel bearings for excessive play. Wheel balance might also be a contributor.
But keep in mind that replacing the steering damper might mask problems with those other components temporarily, without really fixing anything.
You can check yours just like you would test a shock absorber. Once removed, if it extends and compresses evenly, a new one won't make much difference.
Good luck, Mondshine
BlissBignall
PostPosted: Mon Oct 22, 2018 6:43 pm    Post subject: Re: Harmonic Damper? Reply with quote
Thanks! I'll get under there and start checking things.
