New exhaust, rubbing on bumper
BJT
BJT is offline
PostPosted: Mon Oct 22, 2018 5:26 pm    Post subject: New exhaust, rubbing on bumper Reply with quote
Installed a nice looking exhaust that exits out the bumper, as a Thing exhaust should, however, the exhaust isnít quite straight out the center of the bumper holes and rubs badly on the bumper. Iím looking for a silicone/ high temp rubber grommet to put around the bumper exit, has anyone found such a thing or have any other recommendations? Thanks
Wildthings
Wildthings is offline
PostPosted: Mon Oct 22, 2018 6:40 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
The engine moves around a lot as various torques are applied so the pipes need to be pretty well centered in the holes. If you don't have a friend with a torch and/or welder who can fix it for you take it in to your local muffler shop.
Of course you should contact the vendor and manufacture first.
Ron Domeck
Ron Domeck is offline
PostPosted: Mon Oct 22, 2018 7:20 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Since our cars are not built perfect some parts must be fitted. Motor mounts, age, bumper not centered, etc. Try putting a pipe in the tail pipe and move it in place. We have had to do this before.
Ron Domeck
BJT
BJT is offline
PostPosted: Tue Oct 23, 2018 7:29 am    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Well, I bought the exhaust for cheap from a local shop, so no idea who the manufacturer is, might try the pipe in the exhaust to bend it a little, donít know any welders or such. I have seen a pic of a California Thing with a rubber piece around the bumper hole, but no clue where the got that or what itís made out of.
BJT
BJT is offline
PostPosted: Sat Oct 27, 2018 6:37 am    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Found something that may work. Time will tell how it holds up to heat. Looks decent though and quiets the bouncing.
lowsquare
lowsquare is offline
PostPosted: Sun Oct 28, 2018 9:59 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
All I know is that the exhaust gets pretty dang hot. I suspect it's gonna melt those rubber pieces in no time.
Not sure if you can see it or not but I was running a tri-mil exhaust and it was hot enough to melt the rubber on the inside face of those bumper stops.
PRAISE THE LOWERED.
1973 THING
BJT
BJT is offline
PostPosted: Tue Oct 30, 2018 4:02 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Just drove around for an hour, no sign of burning or melting of the rubber. The chrome extensions actually stay relatively cool, compared to the actual pipes... plus they are made of a pretty heavy rubber. Completely eliminated the banging noise. Problem solved!
KAmes
KAmes is offline
PostPosted: Tue Oct 30, 2018 6:00 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Those grommets look nice. Mine bangs a little in reverse, ok going forward.
74 Thing
74 Thing is offline
PostPosted: Tue Oct 30, 2018 7:08 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Where did you get that grommet?
BJT
BJT is offline
PostPosted: Tue Oct 30, 2018 8:23 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
https://www.rubberfeetwarehouse.com/collections/ru...ts-3-holes
Not sure I posted the link right. But I got them from Rubberfeetwarehouse.com
The grommets that fit 3Ē holes with a 5/64 groove diameter
BJT
BJT is offline
PostPosted: Sat Nov 10, 2018 8:27 pm    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Just as a follow-up. Drove from Chicago area to St Louis area today, about 6-7 hours driving, only stopped for gas, grommets showed zero wear/melt. Granted it was 7 degrees outside when I left so everything was a tad cooler, but grommets are working good
Buggy Brian Premium Member
Buggy Brian is offline
PostPosted: Tue Dec 18, 2018 1:05 am    Post subject: Re: New exhaust, rubbing on bumper Reply with quote
Thanks for the update. Just ordered a set for myself, and your link worked great!
-(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-(Gunther) Manx 2 # A0202A035E
-Original Home built buggy that started all. I learned to drive in it back in 1985.
-1974 VW Thing
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983
