chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Mon Oct 22, 2018 11:01 pm Post subject: Panel bonding adhesive? Without two part gun. Anyone try these? |
Its's for my heater channel to floor pan. There is about 1/8-1/4" give when I stand on it and I weigh 290lbs, so not soo bad. I'm gonna treat the rust and then goop it up.
Both of these claim to bond well to steel. dry rock hard
Any thoughts on it?
TotalBoat Thixo Thickened Epoxy Adhesive 185ml Cartridge is $23.
Link: http://a.co/d/7Wm8h2z
Evercoat Fiberglass FIB-815 Maxim Panel Bonding Adhesive is $51.
Link: http://a.co/d/5PmSUwM |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Oct 23, 2018 8:37 am Post subject: Re: Panel bonding adhesive? Without two part gun. Anyone try these? |
I would use something that flexes there and or take care of why it moves so much but not rely on one solution for both issues. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Thu Oct 25, 2018 7:03 am Post subject: Re: Panel bonding adhesive? Without two part gun. Anyone try these? |
theKbStockpiler wrote: |
I would use something that flexes there and or take care of why it moves so much but not rely on one solution for both issues. |
The reason it moves is that the bottom 1/4-1/2 inch of the heater channel is rusted out on the back half of the passenger side. Luckily! the back corner is sold, so I think I can salvage it without replacing it.
But that leads us to why? It seems as if water is entering the body at the base of each rear fender because there is no bead.
This basically acts as a rain gutter sending water into my heater channels and the sill under them and into the floor pans.
So my plan is to, pull the fenders and install the bead, treat the rust, reinforce the heater channels in 2 or three spots with some Stiff metal T-brackets and stainless screws, bond the to the pan channel with panel adhesive. Then strip and rustproof (rust bullet) the pans and reinforce with a little glass. |
Posted: Thu Oct 25, 2018 1:32 pm Post subject: Re: Panel bonding adhesive? Without two part gun. Anyone try these? |
Here's a link with Heater Channel Patch Panels.
https://www.mtmfg.com/vw/2/Volkswagen-Beetle-Heate...s-and-sect
It's up to you if you don't want to replace the entire heater channel or not even if it's more practical to do so.
Cheap generic stainless hardware is brittle in case you have no experience with it.
I would do a competent patch job and seal it up. The heater channel is probably going to be worth replacing at some later date. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
